O2 Sensor help
Originally Posted by RideTheMax
I can't find instructions for replacing the front right 02 sensor. someone point me in the right direction please. thanks.
Mansurkx, you gave the directions for the front left sensor. The front right is the one close to the passenger side strut mount and by a spark plug. It's upside down, but you should be able to recognize it. It has 3 wires.
Paul, you gave the diagram for a cali spec. I don't know why, he has a fed spec. But I guess the photo can still be used. The front right sensor is the B1 front sensor on the top pic.
Just put the car on ramps or jackstands, unscrew with 02 socket or 22mm open ended wrench. Then get out from under the car and find the plug in. It's on a little metal tab, close to one of the spark plugs. It's upside down, so push down the the tab which is facing down, and pull it off. Follow the wire down, and you'll see a bunch of connectors. Pop them all off. Then remove old sensor. Install is the reverse of this.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
