window rolls up stops then rolls up the rest of the way
Old Mar 5, 2004 | 09:21 PM
95maxcntrljrsy's Avatar
ill roll up my window and it will get an inch from closing then stop - it will then pause 5 sec then finish rolling up - anyone know what this is??
Old Mar 5, 2004 | 11:13 PM
boyzindahood978's Avatar
You might have to regrease the window track. Mine does the same thing sometimes, but more at halfway. I believe you can regrease the track with white lithium grease. Correct me if im wrong. Hope that helps.
Old Mar 5, 2004 | 11:25 PM
meccanoble's Avatar
Sports Button FTW
does it sound like its getting stuck or getting weak?
Old Mar 6, 2004 | 01:23 AM
happyricefob's Avatar
V^___^V
broken windows regulator?
my rear power window is broken for a long time. right now i have the window duct tape cuz i don't feel like spending $100 fixing the window. since my windows are tinted, it's not too noticible from outside. my area is pretty safe... so works for now (yea yea it's ghetto i know... )
Old Mar 6, 2004 | 04:21 AM
maxspeed96CT's Avatar
The original VQ...
does it so it when you do one window at at time o when you try to do all of them? because my sunroof does this if i try to close it at the same time as my windows, i think it just stop for safty and so the circuit wont overload or something.
Old Mar 6, 2004 | 08:48 AM
it sounds like the motor stops then clicks back on - now that you mention it i think it only does it while my heats on
Old Mar 6, 2004 | 10:32 AM
maxdick's Avatar
this happens to me too. with about an inch left i hear "click" and it stops. 5 seconds later it will work again. does yours go up by itself, or do you have to wait and still hold the button? i gotta check out this heat thing cause it only happens sometimes so maybe that's it. weird.
edit: it's just the driver's side.
Old Mar 6, 2004 | 02:13 PM
BLAZIN's Avatar
please
yes someone please figure this out mine have done that for a while...i hear the click also and it does seem to be only when there are a lot of power accesories on inside HELP
Old Mar 6, 2004 | 02:16 PM
Rowan's Avatar
happens to me too! What is going on? I don't think there is a definite click but I'll listen harder next time. I think it is only my drivers side front window that does it.
Old Mar 6, 2004 | 02:24 PM
NissanSE98's Avatar
when i roll up my drivers side window and any other window at the same time, the drivers side always finishes last by 2 or 3 seconds
Old Mar 6, 2004 | 02:35 PM
Maxima99SE's Avatar
will fly for food
yep, mine too
Old Mar 6, 2004 | 02:38 PM
Nismotic's Avatar
Always sunny in philly
do you have anything lodged into the window channel? i have weatherflectors that do not sit correctly. otherwise, time to grease.
Old Mar 6, 2004 | 05:17 PM
Shift_my vq's Avatar
No you guys are right it's overloading it. If I have my radio and ac on and try and roll up all the window and the sunroof at same time click for about 3 seconds.
Old Mar 6, 2004 | 07:29 PM
pocketrocket's Avatar
Thw sunroof & power windows are connected to a circuit breaker that trips when it gets too hot. After 3 - 5 seconds, it cools down enough to let you resume the motor function.
To verify that your circuit breaker has tripped, try running another window as soon as your window pause ... if nothing, then the circuit breaker has tripped.
I rarely run more than 2 windows at a time (and definitely not with the sunroof), so mine rarely trips. Be patient, yours won't either. Why strain your poor circuit breaker?
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
