View Poll Results: Just Click On the Each Choice.
Interior Rattles, from the Front End, Dash, ETC...
42.86%
Coil Pack Problems.
53.57%
Auto Tranny Feeling like it is loose and shifts hard.
17.86%
Vibration Problem(engine).
14.29%
Interior rattles from back area and the trunk.
32.14%
Multiple Choice Poll. Voters: 28. You may not vote on this poll
Question From 99 Owners.
Old Mar 5, 2004 | 11:26 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Well, Since I am a member at Maxima.org, and everyone here owns Maxima. I am making this Poll to see what is the Most Problem people having with their 99 Maxima. I am only doing this because I want to know for my self. Since the time I started with maxima.org I did not see any post about some of the problems I am having with my 99 Maxima. If there was a post like this past, Please Remove my post and sorry about posting this.
Old Mar 6, 2004 | 01:03 AM
MAXimumHP's Avatar
The most common problems with 99's are probably the Ignition coils and O2 sensors.
edited due to my drunk @ss typing
Old Mar 6, 2004 | 08:14 AM
BOSS
COIL PACKS^2 = 99 Maximas
Old Mar 6, 2004 | 09:34 AM
sadice's Avatar
i changed one coil pack the front one so far... i dunno one day i start the car and it was bad i still don't know how it went bad ......
Old Mar 6, 2004 | 09:39 AM
XoPtOn's Avatar
*Question for 99 Owners*
ive only had my max for a few months so i havent had any problems yet, but i think my coil pack is goin bad cause the front shakes at a full stop.... but i dont think that 99's are the only ones that have problems ^-^
Old Mar 6, 2004 | 09:50 AM
CystumMax's Avatar
Thanks For all the responses.
Old Mar 6, 2004 | 09:56 AM
BlueC's Avatar
wat
Yea we may have a few problems, I know the rear struts go out early, previous service records show the rear left strut was replaced around 35k miles, now I checked and my rear right strut is leaking.
Old Mar 6, 2004 | 10:53 AM
speedymax99's Avatar
i have my 99 se for three years and no problems
Old Mar 6, 2004 | 04:12 PM
Stillnmax's Avatar
my tranny went... i got my car around November of 99 thats about it
Old Mar 6, 2004 | 04:16 PM
DJMaxGLE's Avatar
Not sure what a coil pack is ( ) but I do hear rattling sounds from the trunk. I think it's the speaker mounts. Could be from all the loud techno music I play. And I also hear a clicking sound from the engine while idling. Don't know what it could be, but other than general maintenance, that's all I know that's wrong with it.
Old Mar 6, 2004 | 05:06 PM
CystumMax's Avatar
Well if you use low grade gas, it will make the car ping, and similar noise to clicking. Well my Knock sensor is bad, and now my car pings. I always use 93 Octane gas. Right now the car burns a lots of gas.
Old Mar 6, 2004 | 05:30 PM
ohannon7's Avatar
Mine is fine,great actually, now everyone knock on wood
Old Mar 22, 2004 | 11:04 AM
billy_corgan's Avatar
Ive had my 99 for one year with 53,000 miles and no problems
Except for a fried clutch, but thats my own fault
Nitrous+burnouts = fried clutch
Old Mar 22, 2004 | 11:12 AM
Jr'sMaxima's Avatar
What exactly would a coil pack problem produce??
I have had no problems (knock on wood) other then an O2 sensor.
Old Mar 22, 2004 | 11:35 AM
MAXimumHP's Avatar
For some reason the 99's coils are manufactured by a different company or something and they seem to fail more often than other years. The common problem is misfire, because the firing event never takes place due to lack of spark.
It reduced power and causes a rich condition in the exhuast, which can cause the O2 sensor and catalytic converter to prematurely fail. Not exactly a catastrophic problem, but still not really good.
Old Mar 22, 2004 | 11:38 AM
sbslacker's Avatar
37k miles so far and I have none of these problems. Only problem I had was the cam position sensor slowly leaking oil (sensor plugs into timing chain cover). Swapped the seal out and that was that.
Old Mar 22, 2004 | 11:42 AM
sbslacker's Avatar
You mean shocks. Struts in the front, shocks in the rear.
Old Mar 22, 2004 | 11:45 AM
My Maxima has struts in the rear. My 95 Maxima also had struts in the rear.
Old Mar 22, 2004 | 12:09 PM
sbslacker's Avatar
Interesting. I thought all 4th gens had front struts and rear shocks but after looking a bit I found this...
1999's w/ rear multi link suspension (meaning shocks I assume)...
http://www.carsdirect.com/research/n...9/gxe/features
1995's w/ rear strut suspension...
http://www.carsdirect.com/research/n...5/gxe/features
Were the 95's & 96's equipped with independent rear suspension? I thought that was only 3rd gens...
Old Mar 22, 2004 | 12:32 PM
It is very confusin with the struts or shocks, lots of manuels say shocks, but they are deffinetely struts under there.
Old Mar 22, 2004 | 12:34 PM
BlueC's Avatar
wat
Yup im 100% the rears are struts. No shocks under there.
Old Mar 22, 2004 | 03:23 PM
Brudaddy's Avatar
The coils are the only thing that I have had in question for my 99. It is an intermittent problem, that comes and goes. It will hesitate at about 3500 rpm, and then pull hard all the way to redline after about 4k rpm. Oh, and my max has 90k on it. I have original struts and springs, and the ride is great!
Old Mar 24, 2004 | 02:18 PM
redlantrn's Avatar
After 107K, all I have replaced are:
* EGR temp. sensor
*drivers side headlight bulb (twice)
Once in a while, I get a squeeking sound from the rear uper strut mounts, but other than that, solid as a drum.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
