Finally pulled the codes... Looks like my suspicions were correct, Knock Sensor..
Old Mar 7, 2004 | 01:00 PM
ch13f's Avatar
After way too long driving around with the SES light on, I finally got outside and pulled the codes.. 03 04 .. just as I suspected. Guess I'll probably order a new KS from jerryromenissan since they are running a pretty good deal right now.
My question though... Since I'm not really confident enough to do this myself, nor do I have the proper tools, would it be a bad idea to just take the car to any old mechanic and have them do the installation?... I'm almost leaning towards taking the car to a dealer in this case, because it IS something that can be screwed up if not done properly. How many hours would they charge me for?...
Old Mar 7, 2004 | 01:07 PM
happyricefob's Avatar
V^___^V
installing KS is just the matter of patience and cutted hand. i see you have done a lot of basic bolt-ons. changing KS is just like that. it shouldn't be too hard if you follow motorvate's instruction and with the following tool:
1. 12mm socket + pivot socket + 9" extention
2. small hand
Old Mar 7, 2004 | 01:25 PM
mansurxk's Avatar
proper tools are actually pretty common tools, check http://www.motorvate.ca/mvp.php/507 you can get the swivel 12mm at sears, the rest im sure you can borrow from soemoen just as i did.
Old Mar 8, 2004 | 06:43 AM
crashmanmike's Avatar
So am I to understand that this Knock Sensor code ONLY indicates a bad knock sensor? I doesn't indicate that the engine is necessarily knocking?
So since I have this code too, just replacing the knock sensor should solve the problem, right? There is nothing else potentially wrong?
Mike
AaronL
Nov 15, 2020 11:52 AM
Mar 12, 2020 12:06 AM
ac max 92
Sep 17, 2015 07:35 AM
