ECU self test did not work on a '95 CA
My check engine light is on and I tried doing the self-test on the ECU, but nothing happens. I tried it many times, waiting 2 seconds before turning the screw back, engine warmed up or cold, etc. The check engine light just stays on steadily when the blinking is supposed to happen.
My Max is a GLE '95 California, so I suppose I should also be able to use an OBD-II reader, but I'm wondering how well that works with the 95-CA because it is not fully OBD-II compliant. Does anyone know what ODB-II functionality is missing from the 95-CA Max?
Thanks...I took the "don't turn past stop" line literally. The screw control needs to be turned a good 30-40 degrees past the line. I heard some relays click under the hood when it reached the max clockwise position.
(The label should say "don't force past the stop".)
jerrod99_se-l
08-27-2015 08:27 PM
kjm900r
08-05-2015 07:14 AM
