Is there a some way to reset
After a very small accident that deployed my airbags, my car wont start!
Is there some type of reset for the airbags so my car colud start?
or is there any other possible problem?
I did a computer read out for the problem but all I got is
Code#P0325 Knock Sensor 1 Circuit Malfunction?
and I got other codes that pointed to the airbags but those are obvious codes because the airbags deployed.
Can my 97 SE be started with our replacing the airbags???
I've also read in a forum that the fuel pump locks up after an accident, is that true?
How to reset SRS(air bag) light –
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine.
If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired. This is a job for your local friendly Nissan dealer.
220k+ A32
Sep 22, 2015 03:08 PM
