Clearance light rewiring to make brighter.
Old Mar 15, 2001 | 02:38 PM
VQracer's Avatar
Didn't someone explain an easier way to do this? Like installing a different type of bulb? I tried the search already.
Old Mar 15, 2001 | 06:35 PM
Sprint's Avatar
i think it was Slickismax that filed down the end of the bulb.. but i wouldn't recommend it..
Old Mar 16, 2001 | 08:39 AM
kingpin's Avatar
1156
I used the 1156 bulb...no problems with it...didn't have to file it down either.
K
Old Mar 16, 2001 | 08:53 AM
Kevin Wong's Avatar
Man,
I've been having trouble getting the stupid clearance light out for the passed few months. Now that I have a Headlight harness and bright headlights, I'd like the clearance light to be slightly brighter.
Old Mar 16, 2001 | 08:56 AM
kingpin's Avatar
Re: Man,
You gotta be patient with it...after you spray WD40 on the ball and socket move it around a little. Then you just have to pull on the light from the bottom, and it should pop off.
K
Old Mar 16, 2001 | 09:10 AM
mAdD MAX's Avatar
That ball-and-socket device is EVIL!! EVIL!!
It takes time...and lots of patience to get it out!
I still haven't gotten it out yet...but I will..and when I do..that ball-and-socket is gonna DIE!
ok I'm done now.
Old Mar 16, 2001 | 01:57 PM
matt calder's Avatar
Its called leverage. get a big long screwdriver, put it in between the ball and the socket and use leverage to pop it out. it is so easy this way.
Old Mar 16, 2001 | 02:19 PM
98BlaximaSE's Avatar
I just used a flat headed screw driver, stuck it in between the balll and socket joint, and just turned, and out it came.
schmellyfart
Sep 25, 2015 04:47 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
kirkhilles
Aug 8, 2015 10:53 AM
Blackwind
Aug 5, 2015 06:35 PM
RealityCheck
Aug 5, 2015 06:18 AM
