trying to reset ecu......help
Old Mar 11, 2004 | 08:04 AM
1fast99's Avatar
I'm trying to reset my ecu but i dont see that screw located on the side of the ecu,is it the one thats labeled idle adjustment cuz i thought its supposed to be a flathead screw this one looks like a phillips.Thats the only screw i see and its set back not flush with the edge.
Old Mar 11, 2004 | 08:08 AM
Brudaddy's Avatar
Mine looked like a phillips too. It doesn't really matter, it will take a small one anyway. I just used a tiny flat screwdriver to do it. I didn't know to pull the sticker back, but instead just poked through it and ripped the sticker. It would probably be better to pull the sticker back from the side if you haven't already.
Also, that resets the codes(turning clockwise until stop....wait 5 seconds......turn all the way back counter clockwise....wait 5 seconds--then repeat again), but from what I understand, it will not reset the actualy ECU. Like I am going to have to reset the ECU so that it will learn some of my new mods more quickly. To do this, just unhook your battery overnite and then it will be reset and immediately start learning all of your new settings.
Hope this helps...
Old Mar 11, 2004 | 11:08 AM
soccstv's Avatar
is that true? unhooking the battery is the same as resetting the ecu?
Old Mar 11, 2004 | 12:05 PM
Brudaddy's Avatar
1. I am telling you it is two different things. To reset the codes if you have an error code and want to clear it off, you use the adjuster screw on the little ECU unit in the car by the Pedal.
2. Unhooking the battery will totally reset the ECU....ie if you have done some mods and want it to recognize the new mods and want it to learn the mods quicker. I think if you don't do that, it takes like 500 or so miles to learn what you have done.
That is what I was saying. They are not the same. See what I mean?
Old Mar 11, 2004 | 12:09 PM
DAVE Sz's Avatar
Hooooooonda.....
Reseting the ECU will not make it get used to mods quicker. No matter what you do it will take pretty much the same time for the ECU to adjust, reseting or not.
gigabyte
Jan 6, 2017 06:05 PM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 22, 2015 03:08 PM
vrajesh123
Sep 22, 2015 04:20 AM
Colossus
Sep 9, 2015 05:46 AM
