help!! y-pipe install
Old Mar 11, 2004 | 02:43 PM
drew76924's Avatar
i can't get the bolts off by the cat they jus wont come off how should i get um off and wut sizes exactly r the bolts the sizes in the forum like don't fit liek they r 2 diffterent size nuts like on the cat end
Old Mar 11, 2004 | 02:46 PM
BadKarma99-4spd's Avatar
go to autozone and get some liquid wrench it will help a lot. as for the bolts i reused my bolts and they worked just fine, but you could go to the stealership and buy two new cat bolts?
Old Mar 11, 2004 | 02:51 PM
MaXAnDy's Avatar
i couldnt get mine off either. I bought liquid wrench and that still didnt do the trick. So I just put one bolt in the front section and one in the middle section and took it o meineke and gave the guy there 5 bucks and he took them off with the air tools.
Old Mar 11, 2004 | 03:09 PM
drew76924's Avatar
but then if he jus took it off did u have him put the new 1 on also or how did u work that cuz u can't drive it without the y-pipe
Old Mar 11, 2004 | 03:14 PM
Broaner's Avatar
2060lbs and falling...
Cough, Get air tools, Cough.
Actually I did this install before I had airtools. I did the same as MaXAnDy. I went to a local shop and they cracked off the bolts. I then drove home. If you leave the Y-Pipe on the manifold it won't be a problem to drive without the rest of the exhaust for a few miles. Lucky for me, my exhaust shop is .1 miles away.
Old Mar 11, 2004 | 03:27 PM
maxima98vspec's Avatar
ummm try pb blaster......
Old Mar 11, 2004 | 03:34 PM
MaXAnDy's Avatar
Yea i just told him to put one of them on, but lightly so i just took it off when i got home.
Old Mar 11, 2004 | 03:42 PM
meanbean's Avatar
Listen to maxima98vspec...PB Blaster is da bomb. You can get it at your local Walmart. Spray that magical elixer on all of the bolts and let it soak for ~15min then spray it again and wait another ~15min. You should have no problem in taking the bolts off now. Remember, struggling is half the fun of modding. It make completion all the more sweet.
Old Mar 11, 2004 | 03:46 PM
drew76924's Avatar
i about wrenched my arm off tryin lol
Old Mar 11, 2004 | 04:00 PM
happyricefob's Avatar
V^___^V
14mm socket with regular wrench will do the job, but you must:
1. get wd40
2. spray and pray
3. pull like a ****
good luck
Old Mar 11, 2004 | 04:10 PM
1. get wd40
2. spray and pray
3. pull like a ****
good luck
my pi$$ works better than wd-40 $hit, i went out and got some PB blaster and never had thoes problems. just soak it and wait. or u can use wd-40 and end up drilling the Fuccers out like i did.....
Old Mar 11, 2004 | 05:09 PM
drew76924's Avatar
do u think that liek midas will install the whole thing for me its cold out and i don't wanna do it in my cold garage
Old Mar 11, 2004 | 05:57 PM
drew76924's Avatar
wut r the 2 rings that come wit the y-pipe were do they go
Old Mar 11, 2004 | 06:05 PM
V^___^V
those are the exhaust gasket. you should put them in between the y-pipe and the header (where the connect). even though those rings look kinda ghetto, but they work really well.
you should have 3 though, 2 for the headers and 1 for the cat. if you don't go to nissan dealership and pick one up. i don't have the exact part number but just ask for maxima exhaust gasket. (i think it was $4-5). if you dont' get it...enjoy the leackage
Old Mar 11, 2004 | 07:34 PM
Intel's Avatar
I just installed my y pipe and due to 120k miles in chicago and the wonderful salt I ended up cutting off the heads of the bolt to get the Y off. Then I took liquid wrench to the studs left it for an hour hten took a propane torch to heat up the metal around the bolt so it expanded a little. Grabbed vise grips and just pulled one of the studs right out. Other one I had to drill out. I love salt/rust.
Old Mar 11, 2004 | 07:36 PM
Broaner's Avatar
Midas won't be very pleased with you but they might do it. Go to your local exhaust shop and have em toss it on. With a lift this can be done in 20 minutes.
Old Mar 11, 2004 | 08:06 PM
yea i had to drill 2 bolts out where my stock muffler connects to the stock b pipe, cause one of the bolts broke off and had a exhaust leak, i spent like hour and a half to drill them out and my car only had 50k miles.....dam utah
Old Mar 11, 2004 | 08:47 PM
ABK's Avatar
ABK
yeah my car has 58,000 miles in chicago weather, acutally it was in georgia it first 30,000 miles. I had to take off the whole exhaust to get those freaken bolts off. And I was at my friends garage with air tools.
Old Mar 12, 2004 | 04:48 AM
cscm094's Avatar
I snapped a stud on my cat... soooo don't do that. Work in pb blaster for like 3 days, then try it with an impact
Old Mar 12, 2004 | 05:12 AM
MaxedOutOfCash's Avatar
Pizda Boy
looks like i'm gonna have fun tomorrow with a jersey driven car that has 123K miles on it. . .
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
Violator
Sep 9, 2015 10:14 AM
