Door light went out...
Old Mar 11, 2004 | 08:20 PM
|Bijan|'s Avatar
UCF Lexus
I was changing my bulbs to hyper whites -- and I pryed the driver's bulb out...and I put the new one in..and it doesn't work. I put the stock bulb in and nothin happened.
WTF? Do I need a new bulb holder?
Old Mar 11, 2004 | 08:22 PM
maxima98vspec's Avatar
mine does that everyonce in a while....just fucc with it a bit and should work, if not then its ur fuse.
Old Mar 11, 2004 | 08:34 PM
Broaner's Avatar
2060lbs and falling...
Psst, flip it around. Anyone got one of these covers lying around. I've done it 50 times before but on 51 it decided to crack.
Old Mar 11, 2004 | 09:44 PM
1FSTMAX's Avatar
You probably caused a short, and blew a fuse while prying the old bulb out.
Old Mar 12, 2004 | 01:17 AM
phillysmoswantd's Avatar
i have this problem too, does anyone know where the fuse is located (what number)
Old Mar 12, 2004 | 06:55 AM
|Bijan|'s Avatar
UCF Lexus
Hmm, is it in the fuse box under the steering wheel? I MUST have my hyperwhites!
Old Mar 12, 2004 | 08:08 AM
ilumo's Avatar
yea.. I just got my polargs in the doors and the piaa dome on... looks pretty good.
Old Mar 12, 2004 | 10:01 AM
venompwr2's Avatar
Mine doesnt work either, and it happened the same way as you. Never got around to fixing it though. Somtimes it comes on, but doesnt shut off when the doors are closed, so unplugged it.
Old Mar 12, 2004 | 01:34 PM
|Bijan|'s Avatar
UCF Lexus
Hm....fock
Old Mar 12, 2004 | 03:20 PM
BORQUA79's Avatar
nycmaximas member
I did the same... But I even tryed swoping the whole harness from my driver to the pass door and still nothing... If its not the fuse or the socket/harness than what is it??? wire?
Old Mar 12, 2004 | 03:34 PM
Broaner's Avatar
Are you guys trying it in both directions. I was being serious in my previous post. On the stock bulb it will work any way you plug it in while an aftermarket will only have two terminals. Thus, it will work only of the two ways.
Old Mar 12, 2004 | 06:03 PM
skiboarder72's Avatar
haha i have the same problem, its a common thing. ****es the hell out of you though because one side works and the other doesn't
Old Mar 13, 2004 | 07:02 AM
|Bijan|'s Avatar
UCF Lexus
Yea I try it one way...flip it over...nothin happens...
Old Mar 13, 2004 | 07:05 AM
Conrad283's Avatar
I need a truck
Old Mar 13, 2004 | 09:52 PM
Thrilla132's Avatar
Same thing happened to me when I was installing an LED in the door. Now no bulb works. I heard that it is a special fuse or relay located somewhere else in the hood. I have no idea, but have heard they can fix if you take it to the Stealership.
Old Mar 16, 2004 | 08:33 AM
|Bijan|'s Avatar
UCF Lexus
.........waiting for an answer...
tick tock
Old Mar 16, 2004 | 08:48 AM
geo1317's Avatar
is it just one side that does not work? if so then you will need to replace the window switch or run wires from the other door. I just ran wires from my other door when it stopped working. The window switch has a BCM that deals with the door light and i have heard that those tend to go alot.
Old Mar 17, 2004 | 02:13 PM
|Bijan|'s Avatar
UCF Lexus
The WHOLE window switch?? Are you sure? I dont think it has anything to do w/ the window.
There aint no fuse for it??
Old Mar 17, 2004 | 03:28 PM
venompwr2's Avatar
This has nothing to do w/ the topic, but I just noticed that you spelled your color wrong on the little profile on the side...serling silver
Old Mar 17, 2004 | 03:54 PM
Maxima99SE's Avatar
will fly for food
when you get the hyperwhites working, can you take a pic of them in the car w/ them on? I've been thinking about getting them soon
Old Mar 17, 2004 | 05:18 PM
MiLLzZ's Avatar
can sumone tell me the number of the door light??? i wanna get red bulbs....if anyone can help...thanx
Old Mar 17, 2004 | 06:51 PM
Menikmati's Avatar
bulb sixe #194
Old Mar 17, 2004 | 07:06 PM
RA030726's Avatar
I'm nutty for Nissans
Wow am I the lucky one? I've messed around with the bulbs and door switch and they still work. Though I did manage to mix up the controls the the drivers door, the rear pass. window switch controls the rear drivers window and vice versa.
Well to help out try this, switch the whole window switch assembly from the drivers side to the passangers side. If the light works then something is wrong in part of multiplex system of the window control. I know this box controls the light and I know the two are innerchangeable.
Old Mar 18, 2004 | 04:47 PM
|Bijan|'s Avatar
UCF Lexus
So...........any other info?
Old Mar 18, 2004 | 05:56 PM
ManualMaxima's Avatar
5th Gen till she dies!
Originally Posted by Menikmati
bulb sixe #194
yep yep 194 or 164 will work as well. Just asking have you tried any other bulbs in that socket? i did not read all of your post man?
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
Hailstatejig
Sep 2, 2015 06:52 AM
