VQ35 internals in a VQ30
#49
The 5th Gen 3.5 runs throttle by wire??? Thought this was in the 6th Gen maxima??
Originally Posted by Larrio
also consider that the vq35de is running a electronic throttle as compared to a cable. So just swapping in the engine will be harder than just bolt on parts and ECU
#52
Originally Posted by formz
There is no 5th gen 3.5 right?
95-99 4th gen maxima: VQ30DE
00-01 5th gen maxima: VQ30DE-k
02-03 5th gen maxima: VQ35DE
04 6th gen maxima: VQ35DE
and yes, all the 3.5 liter engines run a electronic throttle by wire. Try popping open the hood of a 2k2-2k3 maxima and do the following:
1. rev the engine by pulling on the throttle cable to open the throttle plate
2. actually find a mechanical cable controlling the throttle plate
You can't.
#54
I'll be the first to admit I don't know my *** from my elbow when it comes from the year to year differences. That's why I added "right?" at the end because I wasn't sure.
huh?
You can't.
You can't.
#57
what the hell is it with all the n00bs who dont know **** posting in this tread?
this has been done and shall soon be rplecated by several members on this forum
http://forums.maxima.org/showthread.php?t=299441
#58
Well, the search fukking sucks even for us who have donated (I'm not complaining, just stating a fact) so what the hell are we supposed to do? We don't hover around the board 24/7 memorizing every dam post so stfu you ***** wrinkle.
#60
This is a pretty big over haul. You cant just go slapping this stuff together, i'd bet good money you could stroke this moter with a 3.5 liter crank but id bet even more money that youll do more harm to your engine if you try doing with such little knowledge on the subject. the cams might work if you could have someone make an ecu to match the lift, duration and grind of the them but all in all this a fairly extensive project and involves plenty of research. (you probably wont find the answers on this site my friend) good luck though and if you give up id be more than interested in giving those parts a good home.
#61
James92SE
142
01-02-2024 09:23 AM
