4th gen stalls on startup when I put it in gear
Old Mar 13, 2004 | 02:45 PM
RP95MAXPROJECT
When I start my max if i dont allow it 2 warm up...when i put it in gear the RPM's Drop real low and the car stalls....
95 auto max...
any ideas on why this would be happening
Old Mar 13, 2004 | 03:00 PM
Chickan's Avatar
have you tried adjusting your idle? Could be set too low, also grab ECU codes (even if you don't get a CEL) just to make sure your ECU is nice and happy, check for vacuum leaks, etc.
Old Mar 13, 2004 | 03:44 PM
njmaxseltd's Avatar
Clean your throttle body --> www.motorvate.ca has a write up.
You engine temp sensor might need replacement. The Haynes shop manual has instructions to test if it's within spec.
Old Mar 13, 2004 | 03:48 PM
99automax's Avatar
my max dose that also but thats only when its real cold ouside and i don't let it warm up after i get to normal temp then its fine also change the oil it might be the oil is to old thats what help mine also
Old Mar 13, 2004 | 04:56 PM
RA030726's Avatar
I'm nutty for Nissans
yeah my 96 did that, probly idle
Old Mar 13, 2004 | 05:12 PM
ILoveMyMax's Avatar
That happened to my in my 97 auto when I had it. I took it to nissan they did a tuneup of it for abotu 80 bux and it ran great after that. I dont remeber what they did however, I think just change fluids and what not. Best of Luck
Old Mar 13, 2004 | 05:54 PM
Zamorskii's Avatar
Quick question, guys, does Nissan recommend to warm up our cars or not? I know that some don't recommend it for the reason that oil will warm up faster, so it'll get to working conditions faster and don't kill your engine.
Old Mar 17, 2004 | 05:47 PM
pdadi's Avatar
I also have the same problem and it turned out be Air flow meter.
Dealer tod the part costs $488. Mine also has hesitation problem from a complete stop signal. Will replacing MAF will fix hesitation apart from
stalling?
Old Mar 17, 2004 | 06:02 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
95 auto max...
Do you hear any unusual sounds, like ticking or knocking? Especially from the IACV area. Im finding alot of people goto test there ECUs and don't turn the screw all the way counter-clockwise when their done. The ECU goes into a safe mode and this results in a very low idle, especially when in gear.
Lakersallday24
Nov 7, 2024 07:31 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
Finkle
Sep 27, 2015 09:53 PM
MikesChevelle
Aug 10, 2015 10:53 AM
sc10692
Aug 9, 2015 09:37 AM
