How to change bulbs for gauge turn signals
Old Mar 14, 2004 | 01:58 PM
BORQUA79's Avatar
nycmaximas member
I was intrested in changing my green turn signal arrows in my gauge to blue or white. Does anyone know if there's a special bulb that can be swoped or is the color green from a screen covering the bulbs? Is it more difficult than It seems? Has anyone done this Mod, If so please post? Also That noise, Tick Tick Tick from the turn signals, could it be stopped? Is there some relay that makes the noise and could it be removed or bypassed? Thanks for any input...
Old Mar 14, 2004 | 04:33 PM
ManualMaxima's Avatar
5th Gen till she dies!
i dunno i am about to fidn out once i get my leds in the car...
Old Mar 17, 2004 | 04:16 PM
Terran's Avatar
I think the sound could be stopped by removing whatever makes the sound (I'm pretty sure it's not necessary to the blinker's functionality). As for the turn signal color change, I'd also like to know this. I wonder if red cellophane would work like with the clock mod.
Old Mar 17, 2004 | 04:46 PM
maxjetblack's Avatar
that cellophane idea was a genius... i just finished it right now. i changed it to blue. i gotta run out and see how dim it is tho. and i would also love to know how to change the signal color. anyone with write up?
Old Mar 17, 2004 | 05:47 PM
Terran's Avatar
maxjetblack, are you saying you tried it on the turn signals, or just the clock?
Old Mar 17, 2004 | 07:20 PM
RA030726's Avatar
I'm nutty for Nissans
I installed LEDs in the turn signal indicator lights. I first tried red, but through the green there was no light output. I ended up using a white LED and now it is still green but lighter in color. Araffio used blue LEDs and they light up blue, so changing the color is possible. I don't think you can get rid of the green filter but an LED can shine color through it.
I don't think that it's possible to get rid of the tick sound entirely. The tick is the relay clicking and the relay powers the light. No tick, no light. There are aftermarket flasher relays, thats the proper name, that make more noise for older and/or hard of hearing people. Maybe someone makes a quiet relay or quieter, but I'm guessing it's not a direct fit. One thing you can try is insulating it so it is muffled.
Old Mar 20, 2004 | 12:32 PM
no i meant the clock.
so....you cant change the color of the signal with cellophane? anyone tried?
Old Mar 20, 2004 | 08:11 PM
hollaatchaboi's Avatar
What kind of led did you use....what size? and where did you get it?
Old Mar 21, 2004 | 04:47 PM
RA030726's Avatar
Tony told me how to change the color of the turn signals. He sanded down the green (its on the piece of plastic in front of the bulb) then masked off an arrow. I used white 3mm LEDs with a resistors bought off ebay. The 5mm will fit behind the idiot lights just fine though.
Old Mar 22, 2004 | 02:41 PM
BORQUA79's Avatar
nycmaximas member
So the green on the plastic could be removed by sanding? The plastic wasnt orginally green? or in other words solid green throughout? what do u meant by masked off an arrow? I might be mistaken but isnt an arrow already there? That sounds intresting I have to find some time for this one.
Old Mar 22, 2004 | 03:21 PM
RA030726's Avatar
there is a piece of plastic over the 4 lights <- O/D High beam -> it looks black from the front, but obviously light shines through, i guess the plastic is clear in the middle black on one side and green, yellow, blue, green on the other. Am I confusing the crap out of you? Then he must have used tape, maybe electrical tape, to make a new arrow because he sanded the old one off. So to sum it up yes the plastic is clear with just a bit of green on top that can be removed.
Old Mar 25, 2004 | 01:56 PM
What kind of sandpaper (what grit) was used to do this? Don't want to scratch the plastic. Or does it matter since the green is on the bottom?
Old Mar 25, 2004 | 04:14 PM
RA030726's Avatar
i have no idea. maybe just steel wool
Old Mar 25, 2004 | 04:36 PM
wariow's Avatar
yep, you just sand it down, post pics of the white leds when you're done please! I've been wanting to do this mod for the longest
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
sdotcarter
Sep 2, 2015 09:53 PM
iflexsteel
Sep 2, 2015 08:04 AM
