Clearance light issues
Old Mar 14, 2004 | 04:43 PM
maximumspeed's Avatar
Anybody else's clearance lights a B*tch to off? These things will not come off, I damaged my right one trying to get it off , i unscrewed the one screw above the headlight assembly, but it doesn't want to unpop from the clip at the bottom, why?
Old Mar 14, 2004 | 04:55 PM
ManualMaxima's Avatar
5th Gen till she dies!
yea they are...all advise is do not try prying....i just plulled it like a m-f-er
Old Mar 14, 2004 | 05:07 PM
driver824's Avatar
undo the phillips screw.. and then take a large flathead screwdriver and use ur hand to pull back on the housing and then slip the flathead between the clips and then twist the screwdriver like puting or removing a screw. it should pop out easy..
good luck
blake
Old Mar 14, 2004 | 05:19 PM
Tyrexx's Avatar
Yeah I use a screwdriver to pop it out, you need to greese the metal ***** on the inside of the lights, then they will come off MUCH easier next time.
Roymg
Sep 3, 2018 05:10 AM
trasmadean
Jan 20, 2018 05:05 AM
AnsonJ
Jun 2, 2017 01:35 PM
doctorpullit
Aug 20, 2015 05:15 PM
RealityCheck
Aug 5, 2015 06:18 AM
