Lowering plus rims, and Camber question??
I have Matrix springs right now which give the Max about a 2" drop in the front. I am on stock 15" steelies but I have 17" rims enroute to my home and i was wondering if wheel gap would be affected by the bigger size rim. Right now, there is a 1.5 to 2 finger gap from fender to tire. Since i'm getting 17's will the wheel gap become less, or should it stay pretty much the same?
Also, since it is lowered 2"-front, does anyone know of a good camber kit for this kind of drop, or is it possible to get away with stock cambers?Thanbks for all the info.
camber kit >> http://maxmods.dyndns.org/index.php?MaximaCamberKits
www.tirerack.com and read all their information about wheel size
IMO u should replace your tokico blue (HP) shocks with either agx, illuminas, or koni yellow.
I went to the links. The camber one was helpful, but I couldnt find what I was looking for at tirerack. They had great info, but I didnt see if the wheel gap would close up more if upgraded to a larger wheel. Does anyone know from experience?
Originally Posted by GeeShack
Is there not anyone that knows nothing about wheel size and wheel gap, who can answer my question??
-Fellow high schooler
Wheel Gap
Alright I have the spring 2" setup and I just put on 17" 235/45/17 and they were about 1/2 bigger then stock setup. Therefore the gap in the wheel well is decreased slightly. Trust me though its perfect amount. Mine was decreased about 1/2 an inch. I would run camber kits with 2" drop. I did.....
Here's the deal with the wheel gap....
It all depends on the tires you get on your new wheels. I mean, if you get a tire that increases the overall diameter of the wheel/tire combo, then, obviously, you will have less wheel gap. However, for better handling and the point of getting larger wheels is to get shorter profile tires so that your overall diameter stays the same. Otherwise, you start throwing off your speedometer and odometer. YOu don't really want to do that. You want to try to stay within 1-1.5%of your original diameter for the best results.
you can't predict camber it will be diff from car to car....bushing wear...suspension parts tweeked .. ect ect.... my car is at -1.0 left and -1.1 right with the front dropped 2.25" from stock...max allowed neg camber is 1.0 so my car is at or just over the limit....before the drop I had -.6 camber.... in short I will not be adding camber kits at this time .. I am happy with -1.0 ... some neg camber is good... better for the twistys and rember when the front end lifts under accl you gain + camber.... so you get a flatter foot print ...later
