what is most comfortable shocks/struts?
OEM struts are only supposed to be used with OEM springs... so if you want a drop, your best bet is to go with H&R springs (most comfortable, but also the smallest drop) and either Tokico Blue struts or Tokico Illuminas (the latter are adjustable)
Originally Posted by kevlo911
Illuminas(Blues are not GOOD AT ALL) and H&R Springs would prob be your best best. People say its better then stock.
if you want a lowered comfortable ride go with H&R springs and Tokico Illumina Shocks (adjustable so you can set the softness)
you get a 1.4in drop in the front and a 1.3in drop in the back and a great perfroming strut to handle that drop. it is recommended to get Motivational rear upper mounts to add some more suspension travel in the back (about 1 inch) it helps with potholes or when your back drops quick so struts don't have a rough bounce.
If you want mean drop go with the tein s-tech springs. I have them on my max with kyb gr-2 struts and they ride perfect. The drop is about 2.2 front 1.8 rear. If you get 18's you would need this kind of drop or any 2" drop or else you will get a big gap between the wheel and the fender.
............Hmmmm Tokico Illuminas on H&R......sounds kinda right.
Originally Posted by spiff56747
if you dont wanna drop it just get KYB GR2 shocks, or Tokico Blues, theyre designed to be OEM replacements
Gr-2 is 15% stiffer then stock (per KYB Engineer)
Blue - over priced
Originally Posted by Klockpurple
WTF ! 18" need a 2" drop or else. What if you have a body kit that is already sitting 6.5" off the ground in a state like Michigan with ****y streets (winter exempt). Oh my bad, I guess I'll go with the 3.5" wheel gap & the 4x4 look. That saves me $700.00 dollars and sacrifices my cool for $350.00 per inch. Ain't that some crazy *&^*. Well at least my car will be in one piece, and it still breaks *****.
............Hmmmm Tokico Illuminas on H&R......sounds kinda right.to fill it in better. Big wheel gap looks gay thats just my opinion.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
