About to buy shocks and springs, what else do i need?
Old Mar 15, 2004 | 07:04 AM
Noslen's Avatar
I'm about to buy illuminas and eibach springs, what other components do i need on my 98 max se.
Old Mar 15, 2004 | 10:00 AM
GlacialBass's Avatar
You may want to replace the front strut bearings at the same time. A lot of times they're cracked or fairly worn and it's easier to replace them at the same time.
Old Mar 15, 2004 | 11:09 AM
max7's Avatar
I don't know how many miles you have, but you may need dust boots for the struts. To check look behind the wheel and it's a rubber piece that covers the strut!
Old Mar 15, 2004 | 11:11 AM
happyricefob's Avatar
V^___^V
torque wrench and spring compressor
Old Mar 15, 2004 | 11:14 AM
max7's Avatar
You can rent the spring compressor from Auto Zone for free! I'm pretty sure you can also rent the tourqe ranch.
Old Mar 15, 2004 | 12:09 PM
Noslen's Avatar
thanks, but what about dust boots, bearings and chamber kit?
I have 60k miles
Old Mar 15, 2004 | 12:26 PM
tcf_dk's Avatar
With Eibach ssprings,you shouldn't need new camber kit.Unless your car is going to drop 2" or more.I have KYB AGX with Eibach pro kit and it's low but no camber kit needed.
Old Mar 15, 2004 | 12:41 PM
max7's Avatar
I have the same setup and you don't need camber kit.
Old Mar 15, 2004 | 12:48 PM
Brudaddy's Avatar
max7, your car is sooooooo fine! Wow! So clean too.
Old Mar 15, 2004 | 12:50 PM
Brudaddy's Avatar
what about if I bought Progress springs (1.7" and 1.4" drop) or Maxspeed springs(1.5" and 1.4") with KYB GR2's? Would I need a camber kit? I don't think so, because it is a similar setup to the Eibach's.
Old Mar 15, 2004 | 12:56 PM
max7's Avatar
My camber is within specs. It was checked after I did the install, and also recently when I got alligned!
Thanks for the comments!
Old Mar 15, 2004 | 01:14 PM
Neif's Avatar
What if we're bringing out springs and struts to be professionally installed at a shop? Is there anything we need to bring or will they provide the dust boots and bearings, etc?
Old Mar 15, 2004 | 01:19 PM
Noslen's Avatar
They probably could supply you with those things, but they will charge you. Its better to find out if you need it now than later.
1)do we need dust boots? If so, how much?
2)do i need to change my strut bearings? how much?
2)
Old Mar 16, 2004 | 05:48 AM
max7's Avatar
Agreed, but I recommend doing it yourself! You can rent the tools you need from Auto Zone and the job is fairly easy.
Old Mar 16, 2004 | 06:08 AM
Gibby's Avatar
I agree. If you have a friend with air tools the job is both easy AND quick. It took me and my brother-in-law about 2 hrs to do struts and springs. You'll want to check the condition of the strut boots, but I'd go ahead and replace them anyway. You certainly want to protect those new struts. Also, new KYB strut boots will give you a shorter bumpstop, for more suspension travel after lowering with aftermarket springs. I would also replace the strut bearings. If you choose not to do either of these things, they will almost certainly cause problems later.
Old Mar 16, 2004 | 06:25 AM
Noslen's Avatar
how much will these things cost?
imported_Nismo_max
Feb 17, 2016 03:39 AM
Peter Paul
Jan 2, 2016 05:18 PM
Stagnet04
Sep 14, 2015 11:28 PM
Violator
Sep 9, 2015 10:14 AM
