how is your braking system function?
Old Mar 15, 2004 | 10:51 AM
Noslen's Avatar
how is your braking system functioning?
When i brake hard (80-0),
1) on a dry surface the system feels weak and rough. (not smooth compared to when i brake from 30-0) What is causing this?
2) when the ground is wet, the braking system starts to skip (probably some abs system) this is more dangerous then locking for me. I REALLY HATE IT when it does this. is the maxima suppose to do this?
I'm still on stock brakes, i don't think my rotor has ever been replaced (98 se). this might cause the problems. how do you check if you need to machine or replace the rotors?
Old Mar 15, 2004 | 11:10 AM
happyricefob's Avatar
V^___^V
i usually downshift and tap braking for street driving. ie. i'm going 80mph and i wanna brake
1. tap brake till 60mph, OD/off (3,000rpm)
2. tap brake till 40mph, downshift to 2nd (3,000rpm)
3. tap brake and brake before i hit anything, now 0mph.
i have brembo x-drilled rotors w/ hawk HP brake pads all around. just cleaned the entire braking assembly recently. my braking system is B+ for street driving.
Old Mar 16, 2004 | 06:06 AM
Noslen's Avatar
anyone else?
Old Mar 16, 2004 | 07:01 AM
Hed5150
my brakes suck. they are very spongy and i cannot figure out why. i replaced the master cylinder and all that stuff. if i was you just replace the rotors and pads in the front it is easy and not expensive.
Old Mar 16, 2004 | 07:17 AM
Noslen's Avatar
What do you mean by spongy?
Old Mar 16, 2004 | 08:23 AM
95GreekMaxSE's Avatar
he probly means that the pedal has to travel further to stop the car compared to non spongy where the pedal doenst have to travel as far.
Old Mar 17, 2004 | 05:26 AM
Noslen's Avatar
Hey guys,
I know i need to change me pads soon, and do you guys think i should also replace my rotors? I'm kinda tight on cash, but if i really need to i guess i havta do it.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
RWCreative
Sep 21, 2015 11:01 AM
coasterswim
Sep 2, 2015 07:43 AM
A32goldylocks
Sep 2, 2015 06:39 AM
