Cel 0901 ..
Old Mar 15, 2004 | 11:34 AM
SuperFishstick's Avatar
Cel 0901 ..
I got a 0901 Check Engine light code, meaning "Front Right Htd 02 sensor heater" My question is does that mean i have a bad O2 sensor?
Old Mar 15, 2004 | 02:12 PM
anyone? ???
Old Mar 15, 2004 | 03:02 PM
Kevlo911's Avatar
Kevlo for President
0901
Diagnostic Trouble Code 0901 points to a problem with the Front Heated Oxygen Sensor, Right Bank. The right cylinder bank is also called the rear bank. It is cylinders 1,3,5.
The Front Heated Oxygen Sensors are installed in the Y-pipe, the part of the exhaust system which conveys exhaust gases from the exhaust manifolds to the Catalytic Converter. There is an Oxygen Sensor in each branch of the Y-pipe. These sensors produce a signal which varies with the concentration of oxygen in the exhaust gas, as compared to the outside air. This signal is sent to the Engine Control Module which uses it to control the fuel injection system.
DTC 0901 is detected when the current drawn by the heating element in the Oxygen Sensor is out of the normal range.
Possible causes include ...
- harness or connectors (the sensor circuit is open or shorted.)
- a defective Front Heated Oxygen Sensor (right bank).
The heated Oxygen Sensors have two components: a heating element and a sensing element. The heating element may be tested with an ordinary ohmmeter. This test is done with the engine off.
Follow the wires away from the Oxygen Sensor until you find the nearest electrical connector. Disconnect the connector. Viewed with the connector latch at the 12 o'clock position, there are three terminals. They are numbered 1-3, right to left. Be sure to measure the terminals in the connector half which is attached to the Oxygen Sensor, not the one which leads to the Engine Control Unit.
Measure the resistance between terminals 1 and 3.
The factory spec is 2.3-4.3 ohms at 77 degrees Fahrenheit.
Measure the resistance between terminals 1 and 2.
The reading should be infinity (no connection).
Measure the resistance between terminals 2 and 3.
If the resistance measurements are significantly different from the factory specifications the sensor is faulty and must be replaced.
If the resistance measurements meet the factory specifications the sensor may be good and the wiring is defective. You could exchange the two Front Heated Oxygen Sensors and reset the Engine Control Module. Then drive normally and expect the Malfunction Indicator Lamp to turn on again. If you still get DTC 0901 the wiring is faulty. If you get DTC 1001 the sensor is bad.
Old Mar 15, 2004 | 07:09 PM
thanks .. i'll perform the tests soon enough.
jmlee44
Oct 2, 2022 02:13 PM
MaxDD
Sep 24, 2015 06:40 AM
homeofbacon
Sep 23, 2015 07:17 PM
JoshG
51
Sep 21, 2015 10:41 PM
ballerchris510
Sep 10, 2015 09:35 PM
