Stock Intake question
Old Mar 15, 2004 | 03:52 PM
MaxGR97's Avatar
I have a short ram intake, well the past owner put it on, and he took all the stock intake parts out except for the (i think) it likes the ram air part. its a '97, and its the BIG piece that goes right up to the grill, and was where the air used to come in....IS THIS PIECE NEEDED? There is nothing hooked up to the other end of it, BUT there is like a wire screwed onto it up by the big part. Can i just unscrewed the wire box thing, and relocate it so i can take out the whole ram air piece?
Old Mar 15, 2004 | 03:55 PM
mzmtg's Avatar
Minister of Silly Walks
Yes, you can mount that MAP sensor somewhere else with a zip tie or something
Old Mar 15, 2004 | 04:05 PM
MaxGR97's Avatar
...so that the MAF sensor huh??? well i just learned something. So just ziptie to wherever it fits? and what does the MAF sensor do? i mean ive heard of it, but not sure on what it does. Also, theyre just clips holding the ram air on, just pull up?
Old Mar 15, 2004 | 04:17 PM
ManualMaxima's Avatar
5th Gen till she dies!
no the mass air flow is the big black thing with teh square on top, that the big gilter is connected to.
The intake temp sensor is the sensor on the black intake down pip that you are removing. i just stuck mine inside the filter and tightened the filter really good. i am about to make another mid pipe where it has a hoel in in it for it.
this si nto need, and if you remove it it makes you engine bay look much cleaner if it is not covered in dirt and stuff.
Old Mar 15, 2004 | 04:40 PM
MaxGR97's Avatar
this intake temp sensor cant reach the intake filter...so who did you do it? and your sayiin you put it INSIDE the filter (i have a cone filter).
Old Mar 15, 2004 | 04:43 PM
mzmtg's Avatar
MAP...not MAF
Old Mar 15, 2004 | 04:46 PM
yea i justs stuffed ine in the cone filter
Old Mar 15, 2004 | 06:11 PM
MaxGR97's Avatar
Ive never seen someones intake with a wire going into it...So how did you keep the MAP sensor from fallikng outta the filter, i mean is it REALLY far in there or what, i dont understand how its IN the filter.... Also, what would happen if i just DIDNT put the sensor in the filter, is that bad for the car?
Old Mar 15, 2004 | 07:17 PM
you caanot see tehe wire.... i just put it betewwn the stack and the filter and it goes right in there.
you know the hole in the filter where you connect the filter to the car. if you do nto get it yet i will take a pic tomarrow and send it to ya. or you could just tie it somewher in the engine bay...
Old Mar 16, 2004 | 04:04 PM
MaxGR97's Avatar
Ya, id like it if you could sned pics, i dont get it. thanks soooo much
vingodine
45
May 21, 2016 12:46 PM
incubusjohnny
Nov 3, 2015 05:18 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
