cleaned tb a different way.....
I was having some transmission probs with my Maxima, so I decided to clean the throttle body. Instead of cleaning it by removing the complete intake, and spraying brake cleaner and scrubbing it with a brush.
I cleaned with the TB with the engine running. I loosened the coupler that goes to the TB and mid pipe, and pulled it almost all the way out. I left a small gap so that I could spray the tb with the red straw that come with the brake cleaner. I sprayed it, and gave it gas every time the engine was going to die. I did this for like 2-3 minutes or 3/4 of brake cleaner. Then shut the engine off. Afterwards I checked the TB and it was sparkly clean.
Has anyone used this method?
Use SeaFoam
http://forums.maxima.org/showthread.php?t=266435
I'd be concerned about the brake cleaner injested into the running engine and affecting some sensors / seals.
I'd use the brake cleaner on the throttle body if the car was "off" so that it would evaporate and not get into the engine
Originally Posted by d_hammmer
I've heard of people spraying Carb Cleaner / Throttle body cleaner into the mid pipe while the car is running, but not "Brake Cleaner".
Originally Posted by kevlo911
It cleans the intake manifold, since he cleaned the tb, he should do this.
Cleaning your intake/tb with brake cleaner isn't exactly a smart thing to do. It is basically all toluene, which is what intake cleaner is primarily as well. However, brake cleaner is lubeless, while intake cleaner has a certain amount of lube in it on purpose, to lube the tb/iacv/etc.
Also, whatever brake cleaner you are using, do NOT use chlorinated brake cleaner. You MUST use non-chlorinated brake cleaner. Why? Because the chlorinated stuff attacks rubber/plastic. What do you think the gaskets and o-rings in there are made from? A non-chlorinated brake cleaner should work. But why not just use what's intended for it, that is formulated properly for the use?
This is the way to clean old cars. However, I have heard that newer cars with the MAF Sensor should not be cleaned this way. There is pressure in the intake system before the TB, and this way of cleaning eliminates that pressure and the computer cannot adjust correctly.
I have heard that this can damage the MAF, but I am not sure. The best way to clean is to do it with the car off. It doesn't take much more time.
Sure max line, I'll take your VI.
I didn't go through the MAF, i went through the tb. I have done this a few times on Maximas, and have not encountered any problems. I use CRC brake cleaner...
Originally Posted by ImStockBaby
Where EXACTLY do you put in the Sea Foam?? What about the kind that comes in a bottle? (liquid type)
I used to liquid type, I took the brake booster line and let it suck it in( tkae hte hose and leave the manifold side in and use het other end of the 6 inch hose to suck the SeaFoam)
Having a hard time understanding where you sprayed...but I used the pennzoil type stuff ($3) that says its for throttle bodies (not carbs).
i took the airbox and accordian tube off(including maf sensor). I took a rag and cleaned some carbon out at the TB butterfly plate. Then started engine, sprayed right in there. It choked and sputtered without racing the engine about 2K - 3K, but it got the job done. Alot of black smoke came out. So I think you get pretty good cleaning that way. Had to reset ECU after that.
I can only say it can't be great for engine but worked for me.
04-16-2020 05:15 AM
fx4five
10-01-2015 04:58 AM
