Replaced both front O2 sensors, but still getting a code for one of them.
Old Mar 17, 2004 | 03:39 PM
Bmr4life's Avatar
Is it possible that I installed it wrong or something? I only get the code sometimes, like 1 out of 3 times starting the car. any ideas are welcomed, thank you.
Old Mar 17, 2004 | 05:10 PM
spddracer's Avatar
What code is ti your getting ?
Old Mar 17, 2004 | 05:28 PM
MiLLzZ's Avatar
ur supposed to get code 1 or 2 for 02 sensor..bank 1 or 2....i just replaced my 2nd o2 sensor..the one behind the cat....it's all working fine...got the sensor from the dealer...whopping 150 bucks...rip OFF
Old Mar 17, 2004 | 05:41 PM
spddracer's Avatar
Yes there are 2 front 02 sensors and 1 rear o2 sensors on the a32 max.
The front one by the radiator is HO2 S1 B2 , Heated,Oxygen,Sensor,First Sensor, Bank Two
The other front by the firewall is HO2 S1 B1 Heated,Oxygen,Sensor,First Sensor Bank One
The most rear by in the Cat is HO2 S2** Heated,Oxygen,Sensor,Second Sensor
On the newer models with 4 o2 sensor they will be
HO2 S1 B2
HO2 S1 B1
HO2 S2 B2
HO2 S2 B1
Old Mar 17, 2004 | 05:59 PM
Bmr4life's Avatar
i'm getting 10 01 which means Front Left Htd 02 sensor heater.
Old Mar 17, 2004 | 06:03 PM
spddracer's Avatar
Ok . put a volt meter on the 2 outside wires of the o2 sensor plug leave it plugged in thou . Start the car and you should see 12+ volts on the meter . If you dont you may not be getting voltage to the heater which would require more diagnosis . If you do 12+ volts you may have another bad sensor .
Old Mar 17, 2004 | 06:18 PM
Bmr4life's Avatar
i got the O2 sensor from cheapo2sensors.com (or something like that). if it is a bad one, anyone know if i can exchange it for another one?
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 12, 2015 01:54 AM
mls277
Aug 11, 2015 07:18 PM
