Throttle/Throttle Body Install Problem/Question. Need some help
Alright heres the deal,
I installed my throttle body today after having it chromed. The throttle body had the Throttle Position Sensor removed in order to be chromed, now I put everything back in and installed it all, but am having some problems. The problem is my Maxima is revving up when I push the clutch in and put the car in any gear..It'll go from idle at ~650 rpm to revving to ~1700-2000 rpm without me giving the car any gas. Then when I put the car in neutral the rpm will fall back to ~650 again. Any Ideas?? Also now when the car is at idle and in neutral and I "blurp" the throttle, the car hesitates and slowly revs up and then kind of bogs down. Please help me guys I really need the help!
Thanks,
-Nick
Thanks,
-Nick
How do you figure it has to do with vaccum?? I checked the motor for a good hour and a half with no sign of anything being missing/installed wrong...Also I had the car idle for a while with me listening to in the engine bay and there where definately no signs of leaks. I am leading to believe it has to do with the throttle position sensor. Anybody??
-Nick
-Nick
it IS the TPS, you will have to calibrate it exactly, it is a pain in the a$$
http://vbxmaxima.8m.com/tps.html
MaxLife17
Jun 27, 2019 01:37 PM
