1156 Led bulbs will not work
Originally Posted by moose54
Our turn signals are 1156 I bought some 1156 Led bulbs but they do not work anyone know why, The voltage is the same.
To keep from hyperflashing, you'll need a resistor between the hot and the ground on the blinker leads to increase the load. I believe it's a 6 Ohm resistor 50 watt resistor.
http://superbrightleds.com/1157.htm
Go about half way down on that page. In the stock housing, I wouldn't suggest LED 1156 blubs. Since the bulb goes in at an angle, it is very hard to see the blinkers in the day time. Stick with the halogen bulb, or do something similar to what Araffio did and I'm working on. Check page 9 of my homepage for that.
-David-
-David-
Originally Posted by myke321
Are you talking about the front or rear turn signal?
I was trying to change the front I have altezzas that flash red and I wanted the front to match because I have clear bumper. So the only red bulbs I could find were LED ones.
jerrod99_se-l
Aug 27, 2015 08:27 PM
220k+ A32
Aug 17, 2015 03:57 PM
MikesChevelle
Aug 6, 2015 11:36 AM
