Un-responsive brakes
It seems that I need to push the brake pedal down alot for the brakes to actually start slowing down the car, about half way until it actually starts slowing down.
I wasn't really aware of this problem until the other day when I got a new Pulsar as a loan car while my Maxima had a service. Just lightly pressing the brake pedal on that car was enough to slow it down. Understandably, the Pulsar is a lighter car then a Maxima and doesn't require as much force to slow it down, but still, is having to push the brake pedal half way down to begin slowing the car down considered normal? If it's not, what is likely wrong and how do I go about fixing it? I checked the brake fluid, it's at the correct level. Thanks for any help
You don't NEED to bleed brakes when you change rotors but when you see that your brake fluid is begining to turn dark, it's because there is a lot of humidity and the liquid have been heated often.
Theses are some good sings plus the mushy brake pedal that you NEED to change the fluid.
here's how you bleed your brakes >> http://www.greghome.com/Greg's%20Gar...edBleeders.htm
ok, I got the brake fluid changed today at the Nissan dealer, but I still need to push the ledal down half way for it to start slowing down, and then I need to push it down really hard to make it stop. So, if it's not the brake fluid, what else could the problem be? The rotors were plained back in November, and I'm pretty sure the pads were also replaced at the same time, is it possible the rotor is plained too much and there's a larger then normal gap between the pad and the rotor?
Originally Posted by Matt_NZ
ok, I got the brake fluid changed today at the Nissan dealer...
Ok, I'll give it a go and see what happens, it does have ABS so hopefully it'll kick in. It's only something thats started happening in the last year, it used to respond well to the brake pedal. It does seem though that ever since the rotors were done in November it's been like this. I had driven for a good month or two with the warped rotors before they were plained, so maybe that did some damage?
Edit: Sorry 98se5spd, we must have posted at the same time. Where abouts can I find the vacuum hoses to check? Would it be the hoses that are behind the brake assembly on each wheel?
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
