shaving door handles
Old Mar 21, 2004 | 01:29 PM
97neptune's Avatar
i plan on shaving my rear handles, i was just wondering if i can pull the outer handle and still have functioning interior handles, if i can save my self the money from not getting poppers for the rear then,hey why not? i mean no one ever sits back there anyway and if they need to then i just open the door from the inside. so my question is can i just take out the exterior handle or do i need to mess with any components in the door to make the inside handles still function?
Old Mar 22, 2004 | 05:06 AM
euromaxima's Avatar
shaved handles
you should take out the handle, unhook the lock and weld the child safety lock open. you will still be able to open it from the inside. just make sure the safty lock is open cause if you shut your door and the safety lock is locked your screwed. make sure you take your time welding or you will warp the door. if you need anything else let me know.
Brandon
Old Mar 22, 2004 | 09:56 AM
97neptune's Avatar
mabye a picture of the child safety lockand what i have to weld ? is it behind the black plastic switch?
Old Mar 22, 2004 | 03:13 PM
95bkackmax18s's Avatar
yea i did the same thing, i shaved all four and only put poppers in the front(your back doors will still open from inside) and one time for some reason my back door wouldnt open, it was the safty lock and i got it open from the inside- you can reach the safety lock via inside- just so you know and good luck with shaven
Old Mar 22, 2004 | 03:33 PM
99maxx-on19's's Avatar
in my sig u can see my rear doors shaved but i didn't weld the child lock where do you weld from the inside?
Old Mar 24, 2004 | 05:07 AM
euromaxima's Avatar
child lock
Just do a tack on the lever I will try to get pics in the next few days. 95max on 18s did you pull or door panel off inside the car to get to the child lock. my panels are all painted and if it locked on me i would scratch them up so I just welded the lever.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
zmcneely13
Sep 26, 2015 02:26 PM
