*wow* Ks *wow*
Old Mar 21, 2004 | 09:15 PM
ChrisA's Avatar
*wow* Ks *wow*
I'm sure there's a continual stream of Knock Sensor replacement glory stories on here but HOLY $#%& I just did mine tonight!
WOO HOO!!!
You guys probably remember me, the $800 Maxima SE guy.
Well after doing countless other repairs, I had left this off for last to do eventually.
Now after driving it for a couple weeks the lack of power at times was starting to bug me. NO MORE NO MORE.
Got my KS for $85 shipped from one of the ebay guys. Attempted to do it the other day but got frustrated. Borrowed a 12mm flex socket and used a 18" or so extension. I recommend 3/8 stuff over 1/4 for extra leverage to break the old one free. I first tried 1/4" then switched to 3/8" along with a pipe on the ratchet for leverage. I also removed the air filter housing and surrounding ducts for more room, I'm surprised some online directions don't mention that but it helps a lot for the extra couple of minutes to get it off. When putting the new one in, I put one piece of black electric tape over the head of the bolt to make it fit snug in the socket so it wouldn't fall off in there. Worked like a charm and I was able to wiggle the socket off no problem.
After finishing, I first went and reset the check engine light. Checked it again and all clear. Time for a test drive. Well I've read some people saying it takes a couple days for the computer to adjust before feeling a difference. Not me, Immediate Power! I was screaming around and could not stop laughing out loud in the car! I then just starting yelling HOLY SH%% out loud over and over and couldn't stop.
My God this car now flies.
I gotta change the brakes. Whatever POS pads the previous owner put on fade out way too fast under this kind of driving.
Old Mar 21, 2004 | 09:22 PM
car_boy_16's Avatar
Damn man let me steal your enthusiasm for a bit - im jealous! I dont think mine needs a KS - I have very good power right now...Cant wait for Y-pipe and intake and all that shiznito!!! Congrats man!
Old Mar 21, 2004 | 09:48 PM
99maximagxe's Avatar
how long do you think the oem knock sensor lasts? any estimation on intervals when the knock sensors need to be replaced?
Old Mar 21, 2004 | 09:58 PM
Magikone69's Avatar
do you replace the knock sensor only when it gives codes???? my car is a 95 with te original knock on there, if i replace it will i see any gains or wil it be a waste since my current one is not shooting out ecu codes.
Old Mar 21, 2004 | 10:24 PM
Chickan's Avatar
it would be a waste unless it is throwing a code. manually pull your ecu codes, as in my case it didn't throw a CEL, but it pulled the code for KS, I have a new one on the way, i'll let you know how it goes
Old Mar 21, 2004 | 10:45 PM
Magikone69's Avatar
i checked my codes a few days ago, only code i get is 1005 and i already have another thread started to get help, i guess i won get a knock sensor n e time soon.
Old Mar 22, 2004 | 02:21 AM
PeTeRtheEaTeR's Avatar
can u tell me wat the part number was? I'm not sure if the one i'm looking at on ebay's the one for my 95. Thanks.
Old Mar 22, 2004 | 03:30 AM
ChrisA's Avatar
Nissan Part # for the one I got was:
22060-30P00
My car has 180k miles but I've read people on here having to change them anywhere over 100k or possibly even less. I believe the code for it is 03-04 and remember you have to check for the code, your check engine light will not come on for this one. It could always be age just as much as milage. My original one was actually cracked when I pulled it out but that could have happened when I took it out I guess.
My wife actually took the car this morning. I'm waiting to get a call from her to see if she notices it (i kinda mentioned it when i crawled into bed at 1am). If she doesn't notice a difference she's nuts, its not the same car it was yesterday.
Old Mar 22, 2004 | 05:22 AM
s0ber's Avatar
Glad to finally see the power ! :P I just changed it, it was kind of fustraiting trying to stick your hand in that razer blade fest wasn't it... I was forced to duke it out with the blades I didn't feel like waiting to get a swivel :P It was well worth it though.
Old Mar 22, 2004 | 05:36 AM
ChrisA's Avatar
Ok, so my wife called this morning and said...
"Wow, the car flies now!"
"Now when are you gonna get to the belts? They are really squeaky."
Maybe tonight dear.....
Old Mar 22, 2004 | 05:40 AM
DCM Maxima's Avatar
Cool cant wait to put mine in but I'll have to see who I can borrow the 12 mm flex socket from.
Old Mar 22, 2004 | 05:52 AM
Tort's Avatar
I did mind with a regular 12mm box wrench. All I did was spray some liquid wrench on the KS bolt, remove the EGR Solenoid (1 bolt, very easy) stick my hand in there with the wrench then used a screwdriver and my hand for leverage on the other end of the wrench. Was very easy this way, took me under 30 min. to do the job.
Old Mar 22, 2004 | 08:51 AM
billy_corgan's Avatar
I remember when I replaced my knock sensor on my 95 auto. Sadly though it was on the last day I owned the car. Only got to drive the car with replaced knock sensor once. Best $80 I ever spent on that car!!!
Old Mar 22, 2004 | 10:17 AM
PharoNDmist's Avatar
does the knock sensor kill gas milage, because I pulled the 0304 code and my gas is horrible?
Old Mar 22, 2004 | 11:23 AM
Jatan's Avatar
Yep, a bad KS will give you bad gas mileage
Old Mar 22, 2004 | 11:45 AM
ChrisA's Avatar
I hope gas milage seems to improve with this but I'll be of no official word on it. My odometer only works 1/3 of the time so I can't figure out my milage. Maybe someone else can pass on their experience.
Old Mar 22, 2004 | 12:10 PM
Vigo327's Avatar
how do you check to see that the computer is actually reading the ks, regardless of whether it is good or not??
Old Mar 22, 2004 | 04:45 PM
gansemer's Avatar
My mileage went from 25 to 27 mpg after KS replacement (80% highway miles)
Old Mar 24, 2004 | 06:05 AM
crashmanmike's Avatar
Replaced my KS after 110K miles. Yes, it does add a TON of power to the car. I drove for a long time with it out, and never realized what I was missing until I replaced it.
I would strongly recommend taking out the EGR solenoid and using leverage when trying to pop ou the old sensor.
But if you have the code, change it out. You'll be glad you did!
Mike
spazma7ik
Jan 12, 2017 09:38 PM
Finkle
Sep 27, 2015 09:53 PM
jayc5627
Feb 20, 2001 12:06 PM
punkdork
Jan 31, 2001 08:35 AM
NmexMAX
Jan 16, 2001 12:06 AM
