Idle falling below 500 rpm?
Old Mar 18, 2001 | 06:07 PM
max808's Avatar
Whenever I'm driving for more than 30-45 minutes and my engine is fully warmed, my idle falls slightly below 500 rpm's. The car doesn't die, but sometimes kicks. Is this a normal?
Old Mar 18, 2001 | 06:32 PM
Daniel B. Martin's Avatar
No, this is not normal. The correct idle speed is...
- 700 +/- 50 (automatic transmission, in Neutral)
- 625 +/- 50 (5-speed)
Here is some text copied from the factory service manual.
"Idle Air Control Valve (IACV) -- Auxiliary Air Control (AAC) Valve
This system automatically controls engine idle speed to a specified level.
Idle speed is controlled through fine adjustment of the amount of air which
by-passes the throttle valve via the IACV-AAC valve. The IACV-AAC valve
changes the opening of the air by-pass passage to control the amount of
auxiliary air. ... "
You may make a quick test of your IACV-AAC in the following way. With the
motor at normal operating temperature, and at idle, switch the A/C from
"off" to "maximum". Keep your eye on the tachometer as you do this. The
idle speed should dip momentarily and then recover. If it does this, the
IACV-AAC is working. If the idle drops and does not recover, the engine
may stumble, falter, and stall. The IACV-AAC may require cleaning,
adjustment, or replacement.
There are other engine parts which play a role in maintaining the right idle
speed, but the IACV-AAC is the first thing to look at. Good luck!
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
