Ignition Switch Bulb Replacement
Old Mar 24, 2004 | 01:52 PM
redlantrn's Avatar
Can anyone direct me to a good write up on replacing the ignition ring bulbs? (99SE) I cannot find any info in my Haynes, and search is inop.
Thank you for any assistance.
~J
Old Mar 24, 2004 | 03:37 PM
aznprid972's Avatar
remove the 4 bolts under the steering wheel and remove the top and bottom part that covers it. the ring should be able to twist off and is connected by a #74 bulb. it's pretty easy. shouldn't take you more than 5 minutes to remove and replace it.
Old Mar 24, 2004 | 04:30 PM
RA030726's Avatar
I'm nutty for Nissans
5 minute?! First you need to remove the knee bolster, 2 phillips head screws and then pull the panel off to release the clips, unhook the door chime now too. Then there is a metal plate under the steering wheel, 2 10mm bolts and it slides up and off. The there are 6 phillips head screws securing the steering wheel trim remove them. Remove the top piece of the steering wheel trim. Remove the key ring trim piece now. The bottom trim has a huge U shaped clip type thing that hooks to the steering column, so push down on the U shaped thing and pull down on the trim. Then you can pull the keyring light out and change the bulb. What a fun process.
Old Mar 25, 2004 | 11:38 AM
redlantrn's Avatar
thanks for all the info guys. Is there more than one bulb inside? Only the bottom half of the ring is currently illuminated.
~J
Old Mar 25, 2004 | 04:06 PM
RA030726's Avatar
just one bulb
kmitchel
Oct 28, 2015 09:46 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
MikesChevelle
Aug 6, 2015 11:36 AM
maxima297
Aug 3, 2015 12:50 PM
