95 tail light assembly replacement
Old Mar 24, 2004 | 03:30 PM
drewmeister_sd's Avatar
I need to replace cracked lens covers on the RHS of my 1995. I got the 4 bolts off but I can't get the GD assembly out. Do I need to pop out the black case "thing" inside in order to remove it?
Your ideas are appreciated.
Old Mar 24, 2004 | 03:39 PM
happyricefob's Avatar
V^___^V
try to use a phillip flat screwdriver to assist you. even though there's a lot of black glue (aka the nasty stuff on it), but you just gotta pull like a **** until it pops out. if you are still having difficulty, spray some WD40 over the black rubber crap and hopefully that'll help you to pull it out.
Old Mar 24, 2004 | 03:41 PM
MIXXMAX's Avatar
After removing the 4 bolts, push REAL hard. It will come loose. The light is held on with that black, sticky silicone.
Old Mar 24, 2004 | 03:46 PM
Ladzio's Avatar
Using screw driver to assist is not a good idea, you may crack the lense, well it's cracked already...
vingodine
45
May 21, 2016 12:46 PM
220k+ A32
Aug 17, 2015 03:57 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
