Installs on Y-Pipe, Cat, and Full Exhaust
Old Mar 27, 2004 | 06:01 PM
S Cranaw's Avatar
Im going to be installing my exhaust set up with in the next few weeks or so. I have a Budget Y-pipe, Random Technology Hi-flow cat, and full Greddy SP2 system (still waiting on it). I've heard horor stories on rusty bolts and I went to check mine, which I found out are rounder than J-lo's @ss. (I've got metal nubs) Will a dremel be able to cut these off and will the dremel be able to get into the possitions i need to cut off the bolts? Any suggestions for those who installed their own in a snowy and salt filled area like Rhode Island. if i had to bring it somewhere what is a reasonable price for all this work to be done? thanks for the help.
-Steve
Old Mar 27, 2004 | 08:20 PM
BlueC's Avatar
wat
I had a local place torch off the bolts around the cat for $20. The rest of the bolts shouldnt be too bad, its mostly around the cat that are bad. Just make sure you got extensions for the bolts that connect from the ypipe to the header. It can be tricky for a couple of them.
Old Mar 27, 2004 | 10:22 PM
Ant96GLE's Avatar
I had my Y pipe put in today and I had to have the cat bolts torched off, they were rusted beyond recognition, not even jesus with an air gun could take them off. A reasonable price for everything would probably be around $100 to $150 for everything.
Old Mar 28, 2004 | 06:15 AM
nismos14's Avatar
§è~® f®ÈÄk
well you could try to take it all off in one piece remove the stock y pipe bolts and all the hanger's / attachments to the body and u should be all set
Old Mar 28, 2004 | 06:24 AM
metallic97gxe's Avatar
Master Will
you will need to spray some WD40 or some super lubricant/rust remover on the bolts and let it sit for abour 10 mins before you attempt to remove them and you should be fine
Old Mar 28, 2004 | 10:22 AM
S Cranaw's Avatar
I was actually thinking this too... I see your shaking head icon... are you just being sarcastic? (Man I've gotta move to a warm area without snow and salt)
also what size bolts (mm) are used for Y-pipe, cat, and exhaust so i can replace them, any good kind of bolts that wont rust? (Is there such a thing?)
-Steve
Old Mar 28, 2004 | 11:46 AM
Trig's Avatar
btw, make sure to tell us what you think and what it sounds like.
Old Mar 28, 2004 | 11:57 AM
BlueC's Avatar
wat
My ypipe is all connected now, with my custom 2.5" exhaust with the Dynomax muffler (no resonator, stock cat) its pretty loud but it sounds nice. Not to mention the ypipe makes a HUUUGE improvement over stock, it was worth the hours of painful labor installing it.
Old Mar 28, 2004 | 03:10 PM
nismos14's Avatar
§è~® f®ÈÄk
nope i was serious, i would just do that, cuz its not like u're going to need or even be able to use any of those bolts
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
stromm
Aug 27, 2015 04:13 PM
maxinout93
Aug 20, 2015 02:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
