wheels squeaking. BRAKE PAD worn?
Old Mar 29, 2004 | 08:55 AM
iregula's Avatar
My wheels squeal when they are rolling, and my brakes seem a little weak. does anyone know if the indicator for worn brakes intentionally makes that sound? if so, what is the best brake pad replacement solution? thanks
Old Mar 29, 2004 | 11:10 AM
PLUMMAXSE's Avatar
Sounds like you need pads and rotors. The only real way to tell is to inspect the rotors with the wheels off. If you can snag your fingernail dragging over the rotor, that means your pads have hit the rotors.
Old Mar 29, 2004 | 12:15 PM
wariow's Avatar
brake squeekage doesn't necessarily mean worn pads. It's probably the piston or the top and bottom sides of the pads that are rubbing against the the brake pad bracket. Take off the wheel, and look over the rotor and see how much meat the pad has left. if it's more than 2mm around, then it's good, just take out the pads and lube up the sides of the pads and relube the piston sides also and put it back in. It shoulld help eliminate squeekage.
Old Mar 29, 2004 | 01:42 PM
Brudaddy's Avatar
I second that about it not necessarily being the need of new pads/rotors. Sometimes, even when you get new ones, they squeak.
Old Mar 29, 2004 | 02:01 PM
99maxx-on19's's Avatar
skrew that!i have a problem my ride makes a killer noise like a hard thumping sound when i let off the gas but i step on the gas it goes away my.Hole front end makes noise and it bothers the crap out of me
Old Mar 29, 2004 | 02:18 PM
s0ber's Avatar
Broken strut mounts?
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
dcam0326
Sep 8, 2015 11:02 PM
A32goldylocks
Sep 2, 2015 06:39 AM
