Is this the EGR?
Old Mar 31, 2004 | 06:31 PM
DAVE Sz's Avatar
Hooooooonda.....
Is this the EGR?
What he hell is that, what does it do, and is it supposed to be clicking???
Old Apr 1, 2004 | 05:02 AM
goldmax's Avatar
That's definitely not the EGR valve. The EGR valve is located below the throttle body. Trace the hoses and see if they go to the EGR. FYI - for the part you show I've never heard mine making a clicking sound.
Old Apr 1, 2004 | 06:28 AM
Torgus's Avatar
rtfm. really.
Old Apr 1, 2004 | 02:08 PM
DAVE Sz's Avatar
Hooooooonda.....
Thanks Torgus. I already read the faq a million times and it has nothing about the EGR. There was another thread but all the links in tere are dead. Any more of your brilliant ideas?
Old Apr 1, 2004 | 02:41 PM
Radiohead's Avatar
That's the EVAP canister purge volume control valve.
The EGR is located under the throttle body... I can send you a pic, what's your email?
Old Apr 1, 2004 | 02:55 PM
Ladzio's Avatar
right on target!
here is a bit of it...
Old Apr 1, 2004 | 06:18 PM
gmahn's Avatar
Hey Big D,
I've got the same problem you're describing from that part in your picture...kind of a clicking and rattling when I turn the key to the 'on' position (engine not running). I had a trouble code show up last month for a related component but I cleared it and it hasn't come back. Dunno if it's supposed to make those noises.
Are you having any other drivability problems? PM me if you want...
Old Apr 1, 2004 | 07:38 PM
Ladzio's Avatar
Yes, that's completely normal. Not sure exactly, but it has to do with your idle!
Old Apr 1, 2004 | 11:25 PM
DAVE Sz's Avatar
Hooooooonda.....
It's a steady click when the car warms up, every second or so. When the car is just turned on, it has this grinding kind of noise.
Old Apr 1, 2004 | 11:46 PM
paulsfds's Avatar
was your CEL code 0302? the EGR hi/low system? if so, i'm having problems with that light going on and off as well.
Originally Posted by gmahn
Hey Big D,
Old Apr 2, 2004 | 05:01 PM
gmahn's Avatar
Actually, it was 0704 - EVAP system pressure sensor. Pulled everything apart back at the purge canister (have a CA Max) and bench tested everything...all worked fine. Reset the code and nothing has tripped since.
I wonder if a messed up purge volume control valve (like in the picture) would set off a code like that. I can't believe that valve is supposed to click/grind/rattle like that.
Old Apr 27, 2004 | 06:31 AM
XeroX's Avatar
Hella internets
I am having this problem, exept im pulling code 0306 (EGR BPT valve..)
any ideas on what to do? should i try replacing that hose?
Old Apr 27, 2004 | 06:39 AM
Torgus's Avatar
when i said RTFM. f doesn't stand for 'read the faq moron' it stands for 'Read the ****ing manual' in this case that would be the haynes or equivilent.
Old Apr 27, 2004 | 09:17 AM
XeroX's Avatar
Hella internets
yea... fortunatly i did... but according to the picture here, there is a mistake in the Chiltons manual that i have... im just trying to have someone clarify..
right above this thread on the list of threads is my post on my problem... on ther is pics of the manual...
read that and then tell me to read the manual... OR tell me to buy a new one...
shilov
Feb 19, 2024 09:40 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
maxima297
Sep 24, 2015 10:31 AM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 19, 2015 01:07 AM
