HELP....DR mod is giving a CEL code
Old Apr 5, 2004 | 03:02 PM
AusFlt's Avatar
I just did the Drop Resistor mod and now I am getting a code on my ECU. It is 1205...."Line Pressure Solenoid Valve (Automatic Transmission)".
Is this a normal occurance or is there something wrong. If it is going to set off engine codes I dont like it too much.
Help appreciated....
AUS
Old Apr 5, 2004 | 03:06 PM
Sentinal's Avatar
Dont worry about the CEL, I had thought the same thing when I did it. all you have to do is reset the ECU. Just dont use it that much, not good for the tranny.
-Jon
EDIT: Did you disconnect it from the engine bay? or did you use a switch?
Old Apr 5, 2004 | 03:15 PM
AusFlt's Avatar
I disconnected it to see what it was like....then installed the switch....then drove and got the CEL. It may be from the dissconnected drive...But I think I will continue with the install and put a switch inside too. That way I can also manually select it.
AUS
Mar 12, 2020 12:06 AM
ballerchris510
Sep 23, 2015 08:46 PM
JoshG
51
Sep 21, 2015 10:41 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
A32goldylocks
Sep 2, 2015 06:39 AM
