whats the cause of steering wheel vibration at high speeds?
Old Apr 6, 2004 | 06:11 AM
rwatt1981's Avatar
my steering wheel shakes at high speeds,,,anything more than 65MPH. i'm thinking ball joints, or tie rod ends. i know my struts need to be changed as well as my stock GXE suspension because i'm at 61K and it's never been changed before. any thoughts fellas?
Old Apr 6, 2004 | 06:15 AM
maxmobile's Avatar
start with the cheaper fixes first.. wheel balance
Old Apr 6, 2004 | 06:29 AM
RichMax's Avatar
Boosted like Snipes tax refund
Alignment could be off, too. You may also have warped brake rotors.
Old Apr 6, 2004 | 06:49 AM
maxmobile's Avatar
Old Apr 6, 2004 | 06:55 AM
rwatt1981's Avatar
well, i had my tires rotated and balanced about 8K miles ago,,so i can scratch that off. and my brakes are in need of replacing, rotors and pads. thanks guys for helping me narrowing it down.
Old Apr 6, 2004 | 06:58 AM
MaxedOutOfCash's Avatar
Pizda Boy
i woudn't say it's warped rotors unless it's happening when you're braking...
i had the same thing with mine...had balanced (decent tires) on it....
i bought new ContExtreme tires, put them on, and it disappeared...i have about 40% thread left on the new front tires & it's starting to happen slowly again...so I would definitely say it's the tires.
Sam
Old Apr 6, 2004 | 07:08 AM
maxmobile's Avatar
If you go for an alignment they will tell you if it is the ball joint.. they cant do the alligment if it is that. as for the balance it may be that a weight may have fallen off.. did you hit any pot holes since?
Old Apr 6, 2004 | 07:35 AM
Cool J's Avatar
8k miles ago is quite a distance. i just got new tires mounted and balanced and they said bring it in after 5k miles for my rotation and balancing.
Old Apr 6, 2004 | 07:39 AM
Juki5536's Avatar
I'm having the same problem. Real bad shaking of the steering wheel, even the hood is shaking! I believe the Firestone dealer who mounted/balanced my wheels did a crappy job, I'm sure it needs to be re-balanced. My alignment is off too, its pulling to the left. You should check about re-balancing your tires. I think that's the culprit.
Old Apr 6, 2004 | 08:36 AM
zazon's Avatar
same problem here...its not that noticable but its there. im going in for a re-balance and rotation... i just had brakes done all around so I'll keep u guys posted.
Old Apr 6, 2004 | 09:37 AM
rwatt1981's Avatar
Well, I live in maine and our roads are extremely rough,,,pot holes, frost heaves, tons of hills, etc. My brakes are shot, and so is my suspension,,,I have a GXE stock suspension and currently has 61K miles on my car. I bought it used last spring around this time. I need new rotors and pads first, than suspension shocks and struts and tires too. How much are regular brembo rotors? I don't want to spend too much money on the cross-drilled rotors. I'm not looking for hardcore racing, I just want a nice, smooth ride like a Cadillac. My mom has a 2003 GMC Envoy and it rides like a DREAM, barely noticing anything going over bumps, pot holes, frost heaves, etc. It only has 10K miles on so the SUV is basically brand new. Thanks guys for the input!
Ryan
Old Apr 6, 2004 | 09:41 AM
Jatan's Avatar
http://forums.maxima.org/showpost.ph...20&postcount=9
Old Apr 6, 2004 | 09:49 AM
maxima98vspec's Avatar
ball joints...........
trasmadean
Feb 1, 2017 08:20 PM
vingodine
45
May 21, 2016 12:46 PM
02nissmax
Sep 5, 2015 01:50 PM
tnewbs
Aug 28, 2015 10:15 AM
MikesChevelle
Aug 6, 2015 11:36 AM
