Check Engine Soon
Old Mar 20, 2001 | 10:00 AM
_DRU_'s Avatar
This light just came on in my car. does anyone know what this means? here are some specs:
-1997 GXE
-63,xxx miles
-just did stock intake mod
Could this be my 60k mile service? i bought the car a lil over a month ago with about 61,5xx miles. the people i bought it from already moved out of the country, so i cant contact her to fond out if she took it in for the 60k yet. i hope they didnt sell me some junk and then run, i doubt it because the are old grandparents. anyone know?
Old Mar 20, 2001 | 10:18 AM
Daniel B. Martin's Avatar
-1997 GXE
-63,xxx miles
This has nothing to do with your 60K service.
The Check Engine Light is evidence that something is wrong. That
"something" may be any number of things, some major and some minor. It
might be nothing more than a loose fuel filler cap. The Engine Control
Module (the computer) detected a problem and turned on the Check Engine
Light. At the same time it stored one or more Diagnostic Trouble Codes.
Get someone to do a DTC readout for you. This is not a big deal, does not
require specialized "dealer only" test equipment, and should take less than
an hour. When you know the stored DTCs, you will have a fair idea of what
repairs are needed.
If you like to do your own "wrenching" you can do the DTC readout for yourself.
You will find instructions to do a DTC readout and reset
the Check Engine light at:
http://vbxmaxima.8m.com/ecu.html
The DTC "translations" are found at:
http://vbxmaxima.8m.com/ecudecoder.html
Old Mar 20, 2001 | 10:25 AM
_DRU_'s Avatar
Check Engine Soon
Is there a difference? the light on the utmost right "check Engine SOON" is on. is that the same as "Check Engine"?
Old Mar 20, 2001 | 10:56 AM
Re: Check Engine Soon
Look again. If your Maxima is like mine, the light says Service Engine Soon.
Check Engine Light = Service Engine Soon light = Malfunction Indicator Light.
Three names for the same thing.
Old Mar 20, 2001 | 11:30 AM
_DRU_'s Avatar
right...
servie engine soon. yesterday i was messing around with the little plug on the bottom of the "ram air scoop." im sure it has something to do with that. this morning was the first time i started the car after messing around with it.
i just went to my car and the plug from the "ram air scoop" was loose. i pushed it back in and it clicked. i tried a few times to reset my ECU but failed. it could be something else but not sure what. i dont know why i couldnt reset my ECU but should i be ok? do i need to worry cuz im sure it was just that plug, the only problem is that i cant reset it now.
Old Mar 20, 2001 | 11:36 AM
Re: right...
If you carefully follow the instructions the light will reset.
If it won't reset there may be a second problem which keeps turning the SES light back on.
Old Mar 20, 2001 | 03:53 PM
_DRU_'s Avatar
Oh Man...
im such an idiot. i tried it again, but the second time i was turning it clockwise, i overtightened and it popped past the normal. what do i do now or am i totally screwed?
Old Mar 20, 2001 | 05:33 PM
Re: Oh Man...
I don't know. I never had that misfortune. I guess you can turn that screw counterclockwise, forcing it past the stop you already overshot, and hope for the best.
captchaos
Mar 15, 2016 12:18 PM
6spd4dsc
Mar 4, 2016 05:19 PM
cruce91
Sep 20, 2015 10:23 AM
mikebla
Sep 3, 2015 05:37 PM
A32goldylocks
Sep 2, 2015 06:39 AM
