problem with engine when coming to a complete stop...(vibrations..)
Old Apr 7, 2004 | 05:06 AM
MaxedOutOfCash's Avatar
Pizda Boy
Really hard to describe the problem...but when I come to a complete stop, i hear sound coming from the engine (knocking, vibrating, something like that) and i feel it in my break pedal too....when i rev a little bit or put it in neutral, it stops....
i'm hoping someone here had this problem before....first i thought it was in the dash, but it's definitely coming from the engine somewhere...
could it be the knock senor? knocking? I don't know how it's supposed to sound...
or could my rpm's be too low? i'm around 500 when in gear....
please help, it's annoying.
Thanks,
Sam
Old Apr 7, 2004 | 07:47 AM
88MaximaSE's Avatar
i had same problem
Thanks,
Sam
i had the same problem, if your TB is dirty clean it, if it still its shaking at the stop raise the idle up to 750-800 in park. then u should be good to go.
Old Apr 7, 2004 | 07:53 AM
Pizda Boy
i cleaned my TB about 4 months ago... how do i raise the idle?
Old Apr 7, 2004 | 08:12 AM
s0ber's Avatar
I thought the computer controlled the idle?
Old Apr 7, 2004 | 08:20 AM
97blackSE's Avatar
there is a screw on the IACV, a large plastic one with a phillips head on it. Turn it counterclockwise to raise the idle, clockwise to lower it, pizda boy
Old Apr 7, 2004 | 09:26 AM
Scruit's Avatar
U wanna try me young boy?
Also turn off your AC and put your tranny in Nuetral to ensure it's the engine itself that is making the noise. Further diagnosis with a mechanic's stethoscope (really cheap, like $15 from an auto parts store) will help you figure it out.
At idle my engine seemed a little rough but turning off the AC smoothed it out, so now i know it's the AC that was causing the vibration.
Old Apr 7, 2004 | 09:53 AM
Pizda Boy
where? haha...
where is the IACV?
pizda boy?? i'm gonna you the next time i see you
Old Apr 7, 2004 | 09:54 AM
Pizda Boy
it's still cold in jersey so um....no a/c turned on... it happens when i come to a stop...or if i'm in gear....i always thought that the idle might be a little low and i'll try to adjust that first.....
Old Apr 7, 2004 | 10:36 AM
BlueC's Avatar
wat
Could be the coil packs, but since your not a 99 it might not be it. I had the same symptoms with my failing coil pack.
Old Apr 7, 2004 | 02:49 PM
Terran's Avatar
I changed the spark plugs yesterday and it runs alot smoother now. I don't know if that would be enough to make you worried or not though.
Also FYI, idle speed for 1996 and later as per haynes: manual->525 to 625 RPM
Old Apr 7, 2004 | 02:51 PM
Terran's Avatar
Auto->600 to 700 RPM
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
