fuel filter
well if you can't get the hose clamps off, then your only option would be to cut the hoses and put some new clamps on there. be careful because there isn't much slack to begin with so cutting off 1/2" from each tube will make it more difficult to work down there.
just as a warning there is pressure built up in the lines goin in and out of the filter, and by you cutting these will cause lots of gas to shoot all over and make a nasty mess. I suggest you get something to pentrate the screws and do it that way.
Also if you check the FAQ's there is a post on how to properly change your fuel filter out.
Ant
Ant
chances are the rubber hoses wont come off either. take a pair of pliers and clamp the hose LIGHTLY over where the hoseclamps are (before you loosened them) and twist the hose. this should break it loose so that they will come off relatively easily.
Originally Posted by Brudaddy
is it necessary to remove the air filter box though? I am probably going to be doing this Saturday.
No. But it helps a lot. Unless you have 2 elbows in your arms.
Only takes 10 minutes. A well invested 10 minutes. Easier than it looks. Start by removing the filter box top, the filter, and the retaining screws and wires to be removed and disconnected will all be in sight.
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
