My trans is acting up at least i think it is?
Old Apr 9, 2004 | 09:16 AM
Sy0p's Avatar
ok so here is my problem when i slam on the gas like hold it all the way down my max stalls it wont like go inot the next gere like i have to wait a bit maby like 5 to 7 seconds seconds before it kicks in my car is automatic so i was wondering if any of you have any advice on what to do. could it be that a CAI is really dirty and i have to clean out the air filter or is it somthing with the trans or somthing totay diffrent.
Old Apr 9, 2004 | 09:22 AM
TruMax's Avatar
Do you mean it won't downshift for a few seconds or it redlines for a few seconds???
Old Apr 9, 2004 | 10:33 AM
2 Da Max's Avatar
o ****, i hope what happen to me doesnt happen to u, same thing happen to me when my tranny went, it had to reach a certain rpm then it jerked and started to go, check to see if your tranny is leaking if not then its probably your cai but i doubt the cai would be that drastic into accelerating so slow like that.
Old Apr 9, 2004 | 10:45 AM
Sy0p's Avatar
lol this happend to me boefore and my trans was shot i had to get it replaced and its happening again
Old Apr 9, 2004 | 10:46 AM
Sy0p's Avatar
lets say ill be going like 30Mph and then slam om the gas it wont automaticly jerk the car and shift into the next gere ill have to wait like 5 or 7 seconds for it to go.
Old Apr 9, 2004 | 11:12 AM
ch13f's Avatar
That means the transmission is slipping, if I'm not mistaken. Start saving for a rebuild.
Old Apr 9, 2004 | 11:14 AM
Sy0p's Avatar
my seocnd rebult OMFG wouldnt it be better just to get manual i like like 700 in the bank ill moch the rest of from my parents if manual is better
Old Apr 9, 2004 | 11:15 AM
Sy0p's Avatar
ill check my TRans fluid and clean out my air filter and if nothing helps i guess i gotta break the news to my parents OMG im dead.
Old Apr 9, 2004 | 11:24 AM
95Max's Avatar
You said in your orig post that your car stalls. Have you replaced the fuel filter.
How does the car drive other wise?
There is a delay in all 4th Gen trans.
Old Apr 9, 2004 | 11:31 AM
Kevlo911's Avatar
Kevlo for President
Turn your A/C off.
Old Apr 9, 2004 | 11:40 AM
2 Da Max's Avatar
aite look **** the tranny rebuild for now, sounds like your car needs some maintenance, the only way u know u need a tranny rebuild is if u keep burning out like my dumbass used to do. start the car up and see if the tranny is leaking, if anything dont rebuild its going to end up being more money unless its underwarantee, jus by a used one like idid i bought a 40k mile tranny from a 99se for 380 dollars
Old Apr 9, 2004 | 01:18 PM
TruMax's Avatar
"o ****, i hope what happen to me doesnt happen to u, same thing happen to me when my tranny went, it had to reach a certain rpm then it jerked and started to go, check to see if your tranny is leaking if not then its probably your cai but i doubt the cai would be that drastic into accelerating so slow like that."
I had that problem a while ago i had to purchase a new tranny also. That sucks so much. it was because my tranny fluid was dark black and thick instead of red. I should have changed it buy i was stupid. By the way if you're tranny has over 100,000 miles and you need to change the fluid get it "POWER FLUSHED." not just a standard flush.
Anyways SyOp your tranny as you know it is electronically controlled which means when you have it floored at 30 mph it has to go through your ECU and all that fun stuff."I have the same problem" If your air filter is dirty however do change it you will see a difference. Also Spend the extra money and get the K&N it's worth it. Your tranny is not going out don't worry about it. Keep your tranny healthy by not using overdrive all the time and not manually shifting it all the time. And finally if your tranny has over 100,000 miles on it and you need to change the fluid. POWER FLUSH it. Trust me on that one. You don't want to install a new tranny. It puts a hell of a dent in your wallet.
Old Apr 9, 2004 | 03:39 PM
djbrown's Avatar
-Da MTL Brown Boi-
so you mean leaving overdrive "on" all the time is bad ??
Old Apr 9, 2004 | 09:39 PM
-=PK=-Maxima's Avatar
you guys think it would do him any good if he gets a VB mod and not have to rebuild the tranny?
Old Apr 9, 2004 | 11:33 PM
96maxdaddy's Avatar
From what it sounds like is that one of your clutch packs is gone. And the VB mod only changes shift points by changing the way fluid is circulated in the trans. this would only make the cituation worse. You have a couple of choices 1. test it out, or have it looked at to make sure its the trans. I have heard of people buying new ones only to find out it was a pinched or coroded wire in the trans electrical harness. or
2. go out and buy a max with a manual
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
zmcneely13
Sep 26, 2015 02:26 PM
