Velocity Stack
Old Apr 10, 2004 | 12:28 PM
LIMaxin
Velocity Stack
Is it possible to add a velocity stack to an existing midpipe? If so what size would it need to be and where would i be able to get it?
Old Apr 10, 2004 | 12:57 PM
1FSTMAX's Avatar
Call stillen or JWT, and order a pop charger.
Old Apr 10, 2004 | 01:50 PM
Mishmosh's Avatar
The JWT velocity stack fits on the MAF, so yeah, you can use it with a midpipe. That is my setup currently. The JWT support rod no longer works well in the new position so I just got some backstrap at home depot to support it.
Old Apr 10, 2004 | 02:11 PM
LIMaxin
Where can i get just the velocity stack, i dont need the midpipe nor the filter.
Old Apr 10, 2004 | 03:42 PM
DAVE Sz's Avatar
Hooooooonda.....
You can find them at parts stores on-line. They have universal 3" velocity stacks(venturi ring) which is what you should get. I think JEGS or year one had them.
Old Apr 11, 2004 | 01:35 AM
Mishmosh's Avatar
If you have a 3" filter already, you won't be able to use it with the JWT/Stillen part. It uses a very wide diameter filter. If you don't want the theoretical advantages of a velocity stack, you can just get an adapter to attach the filter to the MAF. You can get one at Summit RAcing for about $16. You may need to drill holes though for proper MAF fitment.
Old Apr 11, 2004 | 05:42 PM
LIMaxin
Can you post the link, I can't find it? thanx
Old Apr 11, 2004 | 05:44 PM
ManualMaxima's Avatar
5th Gen till she dies!
yea i think my JWT is 5 1/4 inches. i cannot find a replacment filter for mine. I have a mid pipe on mine. just hit up ebay. they ahve just the stacks for sale. and some even come with a free cheap filter.
Old Apr 11, 2004 | 06:01 PM
LIMaxin
Can you post a link to one that would fit our MAF? I see ones for scooters but dont know if theyd fit. Thanx
Old Apr 11, 2004 | 06:06 PM
Mishmosh's Avatar
http://store.summitracing.com/partde...GRM%2D10%2D500
Old Apr 11, 2004 | 06:14 PM
LIMaxin
I already have the adapter, I need the velocity stack.
Old Apr 11, 2004 | 06:44 PM
Mishmosh's Avatar
Go to JWT's site or Stillen's site. You won't be able to use whatever filter you have. I believe the "popcharger" costs $125 and is sometimes seen used for $60-75.
Personally, I think intakes are like cat-backs...way overrated. You do it because you like to mod or like the sound.
Old Apr 12, 2004 | 12:53 AM
RastaManMax's Avatar
Ditto for the Maxima, the intake system isn't that restrictive to start with and being NA as well, there just isn't that much to gain from an upgraded intake, unless your current OEM filter is dirty and the TB is very dirty, don't expect much except added noise. You might feel a slight difference if any.
LEMAR
Old Apr 12, 2004 | 03:15 AM
with my jwt i can tell alittle differance, not from a stand still as much, but on the highway i get much better pick up without down shiftering from 5th. I think it was worth the money for my cause i got mine for $50 and i did feel little gains. But yes intakes are way over rated and i would never purchase one of $125 or more.
if you have the adaptor which is the stack. i think you are looking for a mid-pipe.
MaximaGuy14
Aug 30, 2015 05:39 PM
Supermachoman
Jun 23, 2010 05:44 AM
StaindMaxima
May 16, 2002 10:08 PM
Chebosto
Apr 7, 2001 11:07 AM
