any way to make brake pedal more sensitive?
Old Apr 10, 2004 | 03:09 PM
SoLid97SE's Avatar
hey guys i'm changing my rotors and pads tomorrow...i was wondering if there is any way i can adjust my brakes so i don't have to push the brake pedal an inch before i feel any braking pressure? i'm pretty sure when the car was new the brakes were a lot more sensitive. last time i got a brake job i thought this would be fixed but it didn't happen. any ideas?
Old Apr 10, 2004 | 03:18 PM
Tyrexx's Avatar
getting that new stuff should help, make sure you havbe full fluid.
Old Apr 10, 2004 | 04:09 PM
drewm's Avatar
Also ask if the brake service includes bleeding the braking system. That usually can bring braking performance back to new. Air and moisture in the lines causes mushyness.
Old Apr 10, 2004 | 04:24 PM
MAXRB8's Avatar
Adding to "drewm" bleeding even a complete change to new fluid will help and least expense, next but more costly braided brake lines ( less expansion under pressure than rubber resulting in better pedal pressure), last and only if necessary brake master cylinder can cause that "inch of nothing" feel in the pedal, but this item will be pretty expensive. good luck
Old Apr 10, 2004 | 04:25 PM
iansw's Avatar
Get a Big Brake Kit.
Old Apr 10, 2004 | 04:52 PM
DAVE Sz's Avatar
Hooooooonda.....
All brake lines are braided. I think you meant to say SS braided lines.
Old Apr 10, 2004 | 10:48 PM
SoLid97SE's Avatar
actually i'm going to do the brakes with a friend at his garage. is it hard to bleed the brakes?
Old Apr 11, 2004 | 12:35 PM
drewm's Avatar
http://forums.maxima.org/showthread....29#post2393829
Old Apr 11, 2004 | 01:43 PM
SoLid97SE's Avatar
thank you!
Old Apr 12, 2004 | 12:21 PM
Brudaddy's Avatar
yup...get stainless steel brake lines.
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
A32goldylocks
Sep 2, 2015 06:39 AM
