Vehicle lights dimming when using window switches...Normal?
Old Apr 10, 2004 | 11:48 PM
eturnl
Does anyone else have this problem, whenever i put my windows up/down or open/close the sunroof, it seems to drain a lot of power and dims my headlights- and if my dome light is on, it will dim that too.... is this normal? maybe weak alternator?
Old Apr 10, 2004 | 11:54 PM
PeTeRtheEaTeR's Avatar
yes...if it bugs you get a hyper ground, or a better battery. Maybe it mite help.
Old Apr 11, 2004 | 12:00 AM
Guttermouf5150's Avatar
whats a hyper ground?
Old Apr 11, 2004 | 12:07 AM
007max's Avatar
yea, it also happends when you hit the brakes, and its especially bad when my base hits... well at least before my amp took a massive shit
Old Apr 11, 2004 | 12:43 AM
ardika's Avatar
I got this problem too. My dash light dims when I am using window switches, brake, and even emergency hazard light.
I tried to do this when the car is off (key to ACC position), turn on the lights....and guess what, everything still dims like just like when the engine is running.
Is this time for a new battery? I have a hyperground installed and the battery to chassis ground connection is recently cleaned.
Old Apr 11, 2004 | 12:49 AM
eturnl
You guys, ground wouldnt make any difference... i dont even understand wtf hyper ground is for other than looks?! ground is ground fellas. and its definatly not the battary, because thats not whats powering your car when the vehicle is on. I just want to know if its normal... or is it a weak alternator
Old Apr 11, 2004 | 01:25 AM
jetblack5spd's Avatar
hyper ground
hyper ground kits actually do work, for this particular problem i dont think that the hyper ground is gonna fix your problem, use a voltmeter and check to see how much power the alternator is giving out and check to see if its between spec. requirements.
Old Apr 11, 2004 | 03:34 AM
it's normal. All cars that my friends and family drive does this. Don't worry about it.
Old Apr 11, 2004 | 04:17 AM
MPMoney$'s Avatar
Pretty sure its normal-- my 1999 Maxima has always done the same thing.
Those power windows are pretty strong and require alot of juice.
Old Apr 11, 2004 | 07:32 AM
Maxima Moose's Avatar
I also think it is normal. I bought a new battery and it did not make a difference. The lights still dimm.
Old Apr 11, 2004 | 07:37 AM
Jatan's Avatar
It's not normal since mine doesn't do that
Old Apr 11, 2004 | 07:42 AM
Kevlo911's Avatar
Kevlo for President
Mine does it. Hopefully Deezo will see this thread and tell us if his car does it.
Old Apr 11, 2004 | 08:18 AM
Capital15's Avatar
Same problem here.
Old Apr 11, 2004 | 08:33 AM
G20Flyer's Avatar
I have a redtop optima and mine still does this. Every nissan car I know of has done this...i think other makes too (honda...etc)...It should really only happen at idle though...
Old Apr 11, 2004 | 09:01 AM
dahman45's Avatar
yea i think its a nissan thing my pathfinder did it and i just got a 99 max and it does it too...
Old Apr 11, 2004 | 09:52 AM
MaxiSpeed97's Avatar
yes, its normal.. chill *****, i don't think there's an easy way to get rid of it
Old Apr 11, 2004 | 09:53 AM
jjacob513's Avatar
my max also ddoes that but when i like bring the windows up my idle sinks anyone have that?
Old Apr 11, 2004 | 10:34 AM
ardika's Avatar
As normal as I would like to believe, I don't think this is normal. My gf's Maxima, 97 SE, does not do this. I tried this on my friend's Maxima, and his does not do this either.
At first, I thought this is due to the alternator. Then, I tried using the power window/brake while the car is off (key to ACC position) but the same thing still happens.
I was about to buy a brand new Optima battery, but then another poster stated that this won't do any good.
Old Apr 11, 2004 | 10:47 AM
RA030726's Avatar
I'm nutty for Nissans
Both if the maxes in my family do it. When I had the hyper ground kit and 12 awg headlight harness in the 96 i dont think it did it much or at all. I hate it still, but the upgraded wires do help.
Old Apr 11, 2004 | 04:19 PM
maximus_pr's Avatar
same here using optima red battery
Old Apr 11, 2004 | 05:35 PM
A32Matt's Avatar
the chrysler cars i work on do the same things, along with my moms two saturns she had. they just seem to require alot of power and the alternator is barely handling that job along with powering the rest of the car.
Old Apr 12, 2004 | 06:56 AM
deezo's Avatar
Since upgrading my alternator to a 200amp setup, I don't have this problem anymore. You guys can look in the General Forum for both of my threads about the 200 amp alternator.
Old Apr 12, 2004 | 08:58 AM
My4DSC's Avatar
Clueless
My car doesnt do it either, but then again the dealer told me I had the cold weather pkg which included a heavy duty battery, starter, and alternator
tsi6001
Oct 3, 2022 10:23 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
homeyclaus
Sep 3, 2015 06:15 PM
doctorpullit
Aug 20, 2015 05:15 PM
kjm900r
Aug 5, 2015 07:14 AM
