Changed Brake Pads but its worse now!!!
Old Apr 11, 2004 | 10:19 AM
superblack98se's Avatar
I finished changing my brake pads last night, and it feels like it has become worse. There is barely any pressure in the brake pedal, I have to push down alot for the car to come to a stop...btw my brake fluid is filled up to the max line??? Does anyone know what is wrong? I used Friction Master Ceramic brake pads.
Old Apr 11, 2004 | 10:29 AM
Krash513's Avatar
This may be a stupid question, but did you bleed the brakes completly??
Old Apr 11, 2004 | 11:01 AM
Krash513's Avatar
If you changed your pads and had to remove any hoses, you let air into the lines and you need to bleed them everytime to get that air out. The air will cause lack of braking and could cause an accident.
Click here for the 4th gen HOW-TO's theres writeups on how to bleed them
Click here
Old Apr 11, 2004 | 03:22 PM
No I did not, one of the pistons popped out, and some of the brake fluid came out, but then I put the piston back in and filled up the brake fluid after re-installing the piston.
Old Apr 11, 2004 | 03:56 PM
Frank Fontaine's Avatar
Click here
FYI there are dead links on that page.
Old Apr 11, 2004 | 04:43 PM
twiggy144's Avatar
If you did the rear pads, did you align the notches at the back of the pads with the notches on the piston? The piston must be turned a little bit further untill notches match.
Old Apr 11, 2004 | 05:12 PM
96maxdaddy's Avatar
If Iam not mistaken it sounds like your piston popped alllll the way out like to the point were you could hold it in your hand. This probably happened because someone got it the car and pushed on the brakes with the caliper off. DONT DO THIS!!!!!!!! This means you let a WHOLE bunch of air into your brakes and they need to bled like NOW. I would not be riding around with that bad of brakes.
Old Apr 11, 2004 | 05:27 PM
Yep, it's not a joke. You cannot compress a fluid, but you can compress a gas. That means you can press on the brakes and nothing will happen since the air is being compressed.
Old Apr 11, 2004 | 05:30 PM
boyzindahood978's Avatar
Superblack, I think all you need to do is bleed your brakes. While your at it, you might as well flush out all the old brake fluid if it hasn't been done before. Air in the line causes a mushy feeling. Hope that helps. And like maxdaddy said, don't ride on it like that because you might get in an accident.
Old Apr 11, 2004 | 06:47 PM
Yah I am going to bleed it tomorrow and change the brake fluid. Thanks for your responses
Old Apr 12, 2004 | 09:04 AM
Chunger's Avatar
My other car is a Hybrid
FYI...
My ISP's discontinued their relations with Earthlink so they deleted my pages...
I need to find a backup of the pages (er, actually the picture files folder) from one of my backup HDs... I already have another host ... S/B back up in about a week or so.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
ag90fox
Sep 9, 2015 12:22 PM
A32goldylocks
Sep 2, 2015 06:39 AM
