detonation after Y pipe
Old Apr 13, 2004 | 11:09 PM
Kahren's Avatar
after i installed my y pipe it seems to be detonationg throughtout the rev range.
this is with anything more then light throttle. is the obd2 unable to give enouf fuel for this mod? i dont really like this and looking at either chippign the ecu or upping the fuel pressure as a cheaper alternative.
Old Apr 14, 2004 | 12:32 AM
A32Matt's Avatar
obd2 has nothing to do with your engine. It's On Board Diagnostics Gen 2. It's there so you can diagnose your car with a scan tool. what you are trying to say is your ecu might be causing this. and with that, i have no educated guess as to what your problem could be. sorry i couldn't be more help
Old Apr 14, 2004 | 02:38 AM
hotshtsr20's Avatar
the ECU would see the added airflow and add more fuel accordingly. the MAF senses exactly how much air enters the engine, so if the engine breathed better from a certain mod, and ingested more air, the computer would add more fuel.
there is something else going on with the install. you sure its detonation and not a leaky flex section?
Old Apr 14, 2004 | 03:32 AM
njmaxseltd's Avatar
You have a bad o2 sensor.
Old Apr 14, 2004 | 06:20 AM
96maxdaddy's Avatar
Yeah what they said about obd2 is correct. and I would be looking for a leak around the flanges and the flex section.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
