No Power
Old Apr 17, 2004 | 08:27 PM
AUSSIE AL's Avatar
No Power
I need help, I have a 1999 maxima that I have owned for 3 years in that time 4 times I have left the car for over 36 hours without starting it and the next day when it starts it spluters and has no power. If I drive it around the block and then leave it for a few hours it works fine. The Nissan mechanic says that it is coils but he can not find that problem when the car is going good. Any ideas , I live in Sydney Australia and they are not a common car here.
Old Apr 17, 2004 | 08:34 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
What kind of Gas do you use? Have you ever had Throttle body cleaned out? Have you done Fuel Injector cleaning? Do you have Check engine Light?
Old Apr 17, 2004 | 08:47 PM
AUSSIE AL's Avatar
I use standard gas, and I have not had injectors cleaned, generally it goes great and when left overnight it starts and drives like a dream.
It does not have a engine check light.
Old Apr 17, 2004 | 08:53 PM
CystumMax's Avatar
Standard gas, You mean like 87 Octane? The recommended gas for our car is 93 octane.
Old Apr 17, 2004 | 09:34 PM
AUSSIE AL's Avatar
The specification for standard in Australia is minimum of 91 octanne, which is reccomended to be used by Nissan Australia.
Old Apr 17, 2004 | 09:52 PM
mansurxk's Avatar
recommended is 91 octane in US, its in the manual
Old Apr 18, 2004 | 12:49 AM
SMOKEYMOUNTAIN's Avatar
do u have a high-wattage stereo system? It could be either the alternator or the battery. 4th gen alternators are notorious for blowing out. There was even a recall for 98 Max alternators. Check ur electrical system first.
Old Apr 18, 2004 | 02:35 AM
AUSSIE AL's Avatar
No, standard system, but is a good point that the battery may lose its charge after so many hours.
Old Apr 18, 2004 | 05:00 AM
Jatan's Avatar
How many miles do you have?
99s have a problem with the coil packs. Since the coil packs are dying and not completely dead, they won't throw a code. A lot of dealers tell you to replace all of them, but that's expensive.
Some people have waited until the car threw a misfire code. Here's what others have done: start the car and open your hood. Unplug your coil packs ONE BY ONE and see if it changes the idle. I think a bad coil will NOT cause the idle to change (since your car is already running on 1 less cylinder). Do this after you've left the car off for 3 days
If you can find someone else with a Maxima, ask them if you can swap their coil packs into your car and see if it still does the same thing
Old Apr 18, 2004 | 07:46 AM
CystumMax's Avatar
My year is 99 and in the manual says 93.
Old Apr 19, 2004 | 12:26 AM
AUSSIE AL's Avatar
60,000 miles, I will play with the coils as you suggest. Thanks
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
