Security LED
Old Mar 22, 2001 | 07:50 AM
BPinson's Avatar
Hello all.
First of all, I tried searching, got 354,578,214,85.25487 hits so it must still be broken. But the increase in site stability is worth the broken search (to a point).
Okay, so I changed out the security LED to a nice blue one to match the rest of the inside of my car. Well, the light went out after about 3 days. I used the same LED that I used to change the color of the window controls. The LEDs in the window controls still work fine, and look kick a$$ I might add. Is their a different LED I should have used? If so, does anyone know what type?
Thanks everyone!
Old Mar 22, 2001 | 08:25 AM
1Phat Max's Avatar
i dont know what led to use but i do know that the current that stck security led get is very little and it can't support high voltage led like the ones in the switches. that's what my machanic told me when i went to get my alarm installed. sorry couldnt help much.....
Old Mar 22, 2001 | 08:41 AM
BPinson's Avatar
Actually that helps tons. I used a 6 volt LED in my door switches and that's also what I used in the security light. I will stop by radio shack tonight and pickup the "3.something" LED.
I'll see what happens.
Thanks!
Old Mar 22, 2001 | 09:50 AM
lighter
You can destroy LED's by over-voltage, but not by under.
If you put a 6V LED in a 3V circuit I would be surprised if it came on at all, if it did it would probably be very dim.
If you put a 3V LED in a 6V circuit I doubt it would have lasted 3 hours, let alone 3 days. They get real hot real fast and sometimes change color as they fail.
Get a meter and check the supplied voltage in Locked and Unlocked state to make sure it doesn't change when the system is armed.
I too changed all the door controls and Dome light to blue LED's. It's great.
I have a problem now because when I disarm the system and open the door I'm only getting a Dim blue LED, I don't get full bright unless I manually move the switch to ON. Anybody else solve this issue already
Old Mar 22, 2001 | 09:04 PM
BPinson's Avatar
I went to Radio Shack and bought a (different than my original LED) Blue LED (5mm, 3.7 volt, 20mA, 2600mcd) PN: 276-316. Installed it and the light came back on and looks GREAT! It's much brighter and better looking than the others that I used in the doors. I think the door ones were too high voltage for the low voltage security LED. It's been blinking and flashing all night (door was open while install my new FSTB, woo hoo).
Hopefully it will not go out again.
Old Mar 23, 2001 | 03:45 AM
Ramius83
If you guys have a Radio Shack.com around your area, they have great looking super bright blue leds. Radio Shack.com is different than regular Radio Shack by the part numbers and by actual parts. I just changed all my interior lights (window switches, a/c, dome, etc) to super bright blue, looks phat. If you want, I will try to get the number for ya'll. Later.
Old Mar 23, 2001 | 05:19 AM
1Phat Max's Avatar
can you please
Can you please post the info. here and also how did you change all the interior lights? i know how to do the doors but what bout other interior lighting. please reply.....
Old Mar 23, 2001 | 05:23 AM
1Phat Max's Avatar
how did you change the security light? did you take the old one off and put in new one? or did you just spile new one into the existing wiring for old security light? please let me know.....thanx
Old Mar 23, 2001 | 03:08 PM
BPinson's Avatar
Easy!
Pop the little black security box out of the dash. You will need to disconnect it from the wire harness (don't let the harness fall back into the hole).
Next, pry (carefully) open the little clips that hold the "face" of the security box on. You should now have two pieces. On mine their was this little gray rubber thing that held the bulb onto the positive and negative terminals. Remove that little thing.
Next, figure out which side of this connecter is positive and which is negative. To do this I hooked the socket back into the harness and touched a new LED to each side until I found out which way worked, then I marked it with a perm. marker.
I found it impossible to reuse the little gray rubber thing. I argued with it for a while then gave up. I just soldered the new LED on.
Put everything back together, open the door, pull the key and...
BLINK . . . BLINK . . . BLINK . . . BLINK . . .
Questions? Just ask!
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
