Oil Pressure Sender?
Old Apr 20, 2004 | 08:00 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Does anyone know where is the location of the Oil Pressure sender unit? Or is there any Oil pressure sender in the Maxima? If not where do I install the after market one that comes with the Auto Meter oil pressure gauge? Thanks.
Old Apr 21, 2004 | 04:12 AM
knight71's Avatar
hope this helps!
http://www.motorvate.ca/mvp.php/514
Old Apr 21, 2004 | 05:03 AM
Dreizehn's Avatar
Originally Posted by knight71
That's it. You'll have to get some brass fittings and tee the gauge sending unit and the oem sending unit together.
Teflon tape can plug the sending units. If you can, use the paste instead.
Old Apr 21, 2004 | 02:57 PM
CystumMax's Avatar
Thanks for the reply
MadMax95
Can you tell me where I can buy the Brass fittings and the tee? If you can explain it better, I am new to this stuff. Thanks.
Old Apr 22, 2004 | 08:43 AM
Dreizehn's Avatar
MadMax95
Most hardware stores carry brass fittings. The only problem is, the sending unit and the tap are both metric. Most of the fittings that you'll find locally are SAE. You'll have to find fittings to convert the two unless you can find a metric tee and nipples that match. Hopefully someone who has done this will post where they were able to find them locally. You can buy them off the internet if you aren't in a hurry to get them...
Old Apr 22, 2004 | 09:35 AM
TylerBorg's Avatar
You sound like you've got experience with this Dan..... ON MY CAR LOL
Old Apr 22, 2004 | 10:23 AM
Dreizehn's Avatar
Oh, btw... don't over tighten the brass fittings....
Old Apr 22, 2004 | 10:26 AM
Broaner's Avatar
2060lbs and falling...
Check out this article on NPM. It explains what you guys have metioned about the thread sizes very well. Nissan uses neither metric or standard threads for the oil pressure units. They use 1/8 BSP(whatever that means). This article is specific to the SE-r's but it appears that all Nissans have this thread type.
http://nissanperformancemag.com/april04/nissport/
Old Apr 22, 2004 | 10:49 AM
Dreizehn's Avatar
Very good information. I just assumed it was metric since the fit wasn't exactly snug.
Thanks...
Old Apr 22, 2004 | 08:21 PM
CystumMax's Avatar
Thank you all for the information, I am ordering that part now.
Old Apr 23, 2004 | 06:35 AM
nadir_s's Avatar
vicodin ... gift of life
the most expensive part was getting that huge deepsocket
Old Apr 23, 2004 | 07:08 AM
Dreizehn's Avatar
A 22mm deep socket? Looks like you could buy five sockets for the price of that oil distribution manifold...
Old Apr 23, 2004 | 10:56 AM
nadir_s's Avatar
i don't understand... you are replacing the oil pressure sender, right? It's like 5 bucks at autozone. I did it about 36k miles ago and no leaks or issues. It was a quick replacement.
Old Apr 23, 2004 | 05:36 PM
Dreizehn's Avatar
He's installing a gauge too looks like...
Old Apr 23, 2004 | 07:26 PM
CystumMax's Avatar
Yes I am Installing a gauge, And i look into replacing the OEM oil pressure sender. Last time I changed my oil i did not see any leaking.
Old Apr 23, 2004 | 09:03 PM
Broaner's Avatar
You don't need a socket to replace the sender unit. A cresent wrench will do the job perfectly and it doesn't cost anything. I used this as a last resort because I couldn't find a 22mm in deep socket; even at Sears. Good choice on going with that unit. I haven't yet heard of anyone on the .org using that. Let us know how it works. It looks like it is very well machined and if NPM gives it a thumbs up it means its pretty d@mn good.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
