Blue LED interior.....
Old Apr 23, 2004 | 07:47 AM
maxspeed96CT's Avatar
The original VQ...
I have my window switches done and my heater controls, can i put blue leds in my stock bose, has it ben done? what else can i change to a blue LED?
Old Apr 23, 2004 | 08:24 AM
MadChef's Avatar
Let's just say that putting LED's in your BOSE is a huge pain in the butt.
If I ever finish it, I'll let you know how it turns out =)
The main problems are space, and as usual, uneven light dispersal.
Old Apr 23, 2004 | 09:22 AM
JDogg96's Avatar
you could always do this to make your clock match http://forums.maxima.org/showthread.php?t=207107 Someone's done this with the display on their bose unit too, but I think they said they had a hard time getting it open.
Old Apr 23, 2004 | 09:50 AM
MaxedOutOfCash's Avatar
Pizda Boy
here's the write up on the bose....
http://www.cardomain.com/member_page...=352601&page=2
Old Apr 23, 2004 | 11:14 AM
RA030726's Avatar
I'm nutty for Nissans
Replacing all the button lights with LEDs would be a PITA. The lights are about the size of 3mm LEDs but mounting the resistor is the tricky part. Im sure it can be done if you can surface mount the LEDs and find another way to install the resistors. Using LEDs would result in "hot spots" which can be fixed. If the LED is sanded, making the light will disperse more evenly. I have all my displays changed to white and the "Disc" LED changed to red. I was going to do the auto CC and Bose illumination in white LEDs but i havent had the time.
Old Apr 23, 2004 | 07:43 PM
ManualMaxima's Avatar
5th Gen till she dies!
i changed all my interior light to blue led's. i changed windows, clamate control, i did my clock and climate control screen to white. i did my hazard and derforster with the deroster active light. i did my crusice contrl and dimmer swicth. the cruise light on the cluster. security blinkinbg light My interior turn signals, and my keyring. i did it all.
it take time. it is not that exspencive just takes plenty of time.
Old Apr 25, 2004 | 10:07 AM
Mximus's Avatar
blue led's
Just curious before i try doing this mod myself. How did you go about changing the led's to blue? Did you switch the led's themselves, or do that little celophane trick or what? Any advice would help. I just wanna do it right the first time. Thanks.
tarun900
19
Dec 20, 2021 06:57 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
