remote entry
Old Aug 23, 2000 | 03:24 AM
southmax
I had to replace the battery in my remote entry and now it doesn't work. Do these things have to be programmed? ( I had a honda that was programmed thru the radio)
Old Aug 23, 2000 | 05:02 AM
Wizeguy's Avatar
Aren't bulletin boards great?
Btw... I got this from <a href="http://web2.airmail.net/scutchen/max_faq/">andi's faq</a> (yes hes da man). The spacing seems a little messed up, but I think it'll work for ya.
<P><FONT SIZE="-1"><A NAME=Remote></A></FONT><FONT SIZE="+2" FACE="Verdana"><B>Q:</B>
</FONT><FONT SIZE="-1" FACE="Verdana"><I>How do I reprogram the
Keyless Remote?</I></FONT></P>
<P><FONT SIZE="+2" FACE="Verdana"><B>A:</B>
</FONT><FONT SIZE="-1" FACE="Verdana"><I>Here's the procedure from
the 1995 Factory Shop Manual</I></FONT></P>
<P><B>Replacing Remote Controller or Multi-Remote Control Unit
(LCU05)</B></P>
<P><FONT SIZE="-1">Enter the identity (ID) code manually
when:</FONT></P>
<UL>
<LI><FONT SIZE="-1">remote controller or multi-remote control unit
LCU05 is replaced.</FONT></LI>
<LI><FONT SIZE="-1">an additional remote controller is
activated.</FONT></LI>
</UL>
<P><B>ID Code Entry Procedure</B></P>
<P><FONT SIZE="-1">To enter the ID code, follow this
procedure.</FONT></P>
<H4><FONT SIZE="-1">Entering "Setting mode":</FONT></H4>
<P><FONT SIZE="-1">(1) Close and lock all doors.</FONT></P>
<P><FONT SIZE="-1">(2) Insert and remove the key from the ignition
more than six times within 10 seconds. (The hazard warning lamp will
then flash twice.) At this time, the original ID codes are
eliminated.</FONT></P>
<H4><FONT SIZE="-1"><B>ID code entry:</B></FONT></H4>
<P><FONT SIZE="-1">(3) Turn ignition key to "ACC"
position.</FONT></P>
<P><FONT SIZE="-1">(4) Push lock button on the new remote controller
once (for example, if door is locked using the remote controller
during this ID code entry enable state, a new ID code can be
entered). At this time, the new ID code is entered. (The hazard
warning lamp will then flash twice.)</FONT></P>
<H4><FONT SIZE="-1"><B>Additional ID code entry</B></FONT></H4>
<P><FONT SIZE="-1">(5) If you need to activate additional remote
controllers, unlock the driver's door, then lock again with door lock
****.</FONT></P>
<P><FONT SIZE="-1">(6) Push lock button on the additional new remote
controller once.</FONT></P>
<P><FONT SIZE="-1">(7) This ID code entry enable state and setting
mode remain until the driver's door is opened.</FONT></P>
<H3><FONT SIZE="-1"><B>NOTE</B></FONT></H3>
<UL><LI><FONT SIZE="-1">If you need to activate more than two
additional new remote controllers, repeat the procedure
"Additional ID code entry" for each new remote
controller.</FONT></LI>
<LI><FONT SIZE="-1">If the same ID code that exists in the memory
is input, the hazard warning lamps will flash twice but the entry
will be ignored.</FONT></LI>
<LI><FONT SIZE="-1">Entry of maximum four ID codes is allowed and
any attempt to enter more will be ignored.</FONT></LI>
</UL>
<P><FONT SIZE="-1">Any ID codes entered after termination of the
"setting mode" will not be accepted. Additionally remote control
signals will be inhibited when an ID code has not been entered during
the "setting" mode.</FONT></P>
Old Aug 23, 2000 | 09:16 AM
PIONEER's Avatar
man that sounds complicated
U sure its not best to just drive down to the dealer and ask them how its done or make a photo copy of the instructions that comes with a new one from Nissan Parts? I'm sure they have a way of doing it.. but Hey if it works thats all we need.
Old Aug 23, 2000 | 09:22 AM
Jeff K's Avatar
The code does not go away..>
I would try another battery before messing with the remote.
I have bought batteries before that were dead, shelf life expiration. Never by batteries from Radio Shack.
Old Aug 22, 2004 | 07:26 PM
gramakant's Avatar
Hello Guys ! I had my remote not working for about an year. The nissan authorized dealer mentioned to me that the controller board was gone and would cost me $100 to replace it. I thought of giving this process a shot and guess what - it worked !
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
intimidator
Sep 5, 2015 07:23 PM
Hailstatejig
Sep 2, 2015 06:52 AM
