Calling all those with Factory Service Manuals
Old Apr 30, 2004 | 01:52 PM
Tort's Avatar
If someone has a FSM for a 96 please post the ECU pinout diagram that tells you what each pin on the ECU is for. I am trying to remedy what I think is an electrical problem. Correct me if I'm wrong but I think it is also the same for a 95 so that would work as well. I'm sure this would be useful to other members as well. Thanks for your help
Old Apr 30, 2004 | 03:27 PM
acj's Avatar
acj
I have a FSM I downloaded a few months ago...I can look when I get home to see if it has anything on the ECM. I'm pretty sure it goes from 1994 to 2004.
I would put up the whole manual for download....but I'm 56k
Old Apr 30, 2004 | 03:34 PM
Exviticus's Avatar
hey when you get home could you look up how to change the rear brakes on a 96 maxima i change the front brakes already and i have taken out the back brakes but i cant figure out how to release the pressure on the back brakes piston in the calipers.. if you would could you help me
Old Apr 30, 2004 | 03:54 PM
acj's Avatar
acj
im gonna go home in a little while---but i believe to push the piston back in you actually "turn it". Instead of using a C-clamp you will need a special tool to do this. Any part store should have a cheap one, and it looks like a small cube. To use it just turn it clockwise to push it back in. If you're pretty good with tools you could probably use a pair of pliers to do this, but the small cube thing works a whole lot better/easier.
I think this is how it should be done, most of the brakes I have worked on have been like this.
but if you want I can still look...
adam
Old Apr 30, 2004 | 06:48 PM
Exviticus's Avatar
na thats alright thats what i had to do thanks
Old May 3, 2004 | 05:19 AM
Tort's Avatar
acj,
Can you email me the 96 section of the FSM or at least post the ECU diagram? <email>dungdna@rocketmail.com<email>
Anyone else,
if you have a FSM this would be really helpful to me
Old May 3, 2004 | 09:04 AM
acj's Avatar
acj
acj,
Anyone else,
Email sent, hope it helps you out!
Mar 12, 2020 12:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
jwright36
Sep 8, 2015 11:45 AM
jfl330
Sep 4, 2015 01:44 PM
